Homebrew PCBs
pcb foil to DXF file conversion.
2008-05-27 by gus_452000
Hi I have a nice simple homebrew PCB mill and it works very well, the
problem is at present I scan the artwork onto my PC and redarw this
with a CAD package (by hand!) save as a DXF file and then run it
through ACEconverter which generates the G codes needed by the milling
machine.
Does anyone know a simpler method of changing the artwork/layout say
out of a book/magazine into the G codes?
I have tried WinTopo but this does not do it correctly as the machine
simly does not follow the traces it simply goes back and forth doing a
dot here and there until the whole artwork is done but in a very large
amount of time.
So anyone know how to tyake simple artwork, scan change from BMP to
DXF, to G codes in a better way than redrawing by hand?
many thanks
regards
Gus M0IKB
Re: pcb foil to DXF file conversion.
2008-05-28 by pork_u_pine2000
> machine.
> amount of time.
> many thanks
> regards
> Gus M0IKB
A while ago I looked for a good bitmap to vector conversion program
but did not find anything that worked for me in the open source world.
 My search was not exhaustive and I may have missed something.
In the end it seemed worthwhile to upgrade an old copy of the Corel
Draw Suite I owned just to get the Corel Trace module.  The graphics
software world is very competitive so Corel's upgrade terms were very
liberal (my old package was *ancient*).  I got all the other vector
drawing, bitmap editor, lots of format conversion possibilities, etc.
in the deal.
While I really prefer to use (& support) open source and small
shareware vendors whenever possible, sometimes there is no really good
alternative.
-- Dave
Re: [Homebrew_PCBs] Re: pcb foil to DXF file conversion.
2008-05-28 by Hugh Prescott
Check out KellyCAM and Mach 3 at ArtSoft.
I know that Mach 3 will load DXF files and cut them but only certain
linetypes.
Hugh
>> machine.
>> amount of time.
>> many thanks
>> regards
>> Gus M0IKB
> in the deal.
> alternative.
> -- Dave
2008-05-28 by warrenbrayshaw
> > So anyone know how to take simple artwork, scan change from BMP to
A quick search over at CNC.com brought up these two possible
solutions from the forums. A longer read there shows others.
At Science Specialists they have ACME Profiler - Coyote Edition
http://www2.fwi.com/~kimble/scispec/scispec.htm
And
meshCam over at www.robgrz.com
There's a DOS program bmp2cnc that maybe useful also.
All the best
2008-05-28 by Mike Schoenborn
The newer versions of the open source Inkscape (www.inkscape.org)
have a "tracing" capability that might provide a workable approach.
The program's preferred format is .SVG, but it can import plenty of graphic
formats (including .BMP), and export plenty of others (including .DXF).
When tracing you can tweak values for brightness, edge detection, and
color quantization, then when you have a good line representation of
the original, apply "simplify path" which will smooth curves and reduce
the number of line segments in the output.
I used the feature once when converting a company logo from bitmap
to vector and was surprised at what it could do.  The input had lots of
curves and text... think of a 60-tooth gear with serif font text on the
inner circumference, just about zero straight lines... which gave the
program a good workout.  I think if the input was mostly straight lines
and regular angles, like a pcb layout, it might do a great job.
When working with the program's user interface I have a little difficulty
switching my brain from engineering mode to artist mode, but that's
probably good mental exercise.  It ain't no CAD program, that's for sure.
Mike
