Homebrew PCBs
PCB Antenna
PCB Antenna
2009-02-09 by Brian
I have been researching PCB Antenna's and found that they can be
complicated. What I would like to know.. does anyone have a genaric
layout for a 50 ohm 433MHz PCB antenna, if not a layout than how I
could do it. A tutorial would be cool too. I am using Eagle CAD. I am
going to try to etch it myself. I am only looking at a distance of less
than 100 ft at about 2400 baud. I made a tempreture datalogger and
would like to add a wireless unit for an outside temp.
Brian
Re: [Homebrew_PCBs] PCB Antenna
2009-02-09 by Simao Cardoso
> less
I remember that integration IA4420/21 had documentation and layouts (in
pdf) of various pcb antenas for 315/433/868/915MHz,  i couldn't found
the original url now. The files are IA_ISM-AN1.pdf and IA_ISM-AN2.pdf
you can still found them, if not ask me by email. I start a design but
bought it already made and cheaper...
Simao
2009-02-09 by leon Heller
To: <Homebrew_PCBs@yahoogroups.com>
Sent: Monday, February 09, 2009 1:57 AM
Subject: [Homebrew_PCBs] PCB Antenna
The antenna itself is generally simple - a dipole or 1/4 wave with a
groundplane. What complicates things is the matching network that is usually
required.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
http://www.geocities.com/leon_heller
Re: PCB Antenna
2009-02-09 by Juan EA7FNJ
hi everyone!
Try this: http://www.signalengineering.com/ultimate/gamma.jpg
It's easy.
> Thanks,
> Brian
2009-02-09 by Malcolm Parker-Lisberg
If you go to http://www.archive.org and click on the advanced search and paste in the full URL below into the new search,for each file, it returns the PDFs.
http://www.integration.com/docs/IA_ISM-AN1.pdf
http://www.integration.com/docs/IA_ISM-AN2.pdf
--- On Mon, 2/9/09, Simao Cardoso <simaocardoso@...> wrote:
Subject: Re: [Homebrew_PCBs] PCB Antenna
Date: Monday, February 9, 2009, 5:10 AM
> less
pdf) of various pcb antenas for 315/433/868/ 915MHz,  i couldn't found
Simao
This stupid Yahoo email system has sprinkled spaces all over the links, remove the spaces from the links to ensure URL links work.
Date: Monday, February 9, 2009, 9:04 AM
            If you go to http://www.archive. org and click on the advanced search and paste in the full URL below into the new search,for each file, it returns the PDFs.
http://www.integrat ion.com/docs/ IA_ISM-AN1. pdf
http://www.integrat ion.com/docs/ IA_ISM-AN2. pdf
To: Homebrew_PCBs@ yahoogroups. com
> less
Simao
2009-02-09 by Jack Coats
integration.com is now some catchall site and is for sale.
> From: Simao Cardoso <simaocardoso@...>
>> less
> Simao
Please read the message again, I did not say to visit the site of the links given, but to use it as search criteria in the www.archive.org site. If you do what I suggested, you get the documents.
Date: Monday, February 9, 2009, 5:08 PM
            integration. com is now some catchall site and is for sale.
> From: Simao Cardoso <simaocardoso@ gmail.com>
>> less
> Simao
> http://groups. yahoo.com/ group/Homebrew_ PCBsYahoo! Groups Links
Re: PCB Antenna
2009-02-20 by Steve
Look in Microchip's App Notes under rfPIC, they have several that
cover PCB antenna design for that band.
<http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1469>
If that link doesn't work, go to their home page and click on "App
Notes & Source Code" and then "rfPIC Devices", then select "ALL".
Steve Greenfield
> Thanks,
> Brian
Re: [Homebrew_PCBs] Re: PCB Antenna
2009-02-20 by Malcolm Parker-Lisberg
To repeat the message I sent on 9th Feb
--- On Fri, 2/20/09, Steve <alienrelics@...> wrote:
Subject: [Homebrew_PCBs] Re: PCB Antenna
Date: Friday, February 20, 2009, 4:43 AM
<http://www.microchi p.com/stellent/ idcplg?IdcServic e=SS_GET_ PAGE&nodeId= 1469>
Steve Greenfield
> Thanks,
> Brian
Re: PCB Antenna
2009-02-20 by Steve
I think we all saw that.
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, Malcolm Parker-Lisberg
returns the PDFs.
> From: Steve <alienrelics@...>
several that
> Steve Greenfield
