Glad to hear that was it!
Kip
--- In bc2000@yahoogroups.com, smokeystovernyc <smokeystovernyc@...>
wrote:
> Kip:
> This worked!
> So, send the preset from BC Manager to the BCR. Then change the
preset on the BCR and return back to the preset you just sent and save.
> For me, that extra step of changing the preset and returning doesn't
flow very well. But that is crucial, and it is what it is. I must
have missed this detail in the BC Manager manual. It should be in
big, bold, underlined print :)
> Thanks very much for this power tip. I'm working on a step
sequencer preset for Kore 2 and Live 7, and this midi channel issue
was impeding progress.
> joel
> From: k5kip_1999 <k5kip_1999@...>
> Sent: Thursday, January 01, 2009 9:11 AM
> To: bc2000@yahoogroups.com
> Subject: [bc2000] Re: BC Manager midi channel issue
> Argh.... I meant did you change the preset...
> after you send it push the preset button then come back to the preset
> you want to use.
> --- In bc2000@yahoogroups.com, "k5kip_1999" <k5kip_1999@> wrote:
> > Did you change the channel first before trying the preset?
> > I have found that if I send a preset, for the bcr to settle I have to
> > switch the preset to something else then come back.
> > If you are using the preset buttons you might have to cycle the power
> > on the bcr.
> > Try that, if you haven't already.
> > Maybe post your preset so we can look at what you are doing...
> > Kip
> > --- In bc2000@yahoogroups.com, smokeystovernyc <smokeystovernyc@>
> > wrote:
> > > Mark,
> > > Yes, I am referring to the individual channels assigned to buttons
> > and encoders. In BC Manager, I have, for example, all of the cc's in
> > preset 3 set to send on channel 3. Then, I send the preset to the
> > BCR2000, and it receives the preset succuesfully. However, when I
> > check the channel for each button and encoder by accessing the
> > BCR2000 edit menu, channel 16 is assigned to each one. I have
> > verified this by monitoring the midi output with Bome's Midi
> > Translator...channel 16 for everything.
> > > Thanks for the reply, Mark.
> > > joel
> > > -----Original Message-----
> > > From: Mark van den Berg <markwinvdb@>
> > > Sent: Wednesday, December 31, 2008 1:29 PM
> > > --- In bc2000@yahoogroups.com, joel stover <smokeystovernyc@>
wrote:
> > > > Problem: When I transfer a preset from BC Manager, it doesn't
> > > matter what midi channel I have set, it always ends up being
channel
> > > 16 after transferring to the BCR. I know that I can change the
> > > channel manually with the BCR, but that kind of defeats the
> purpose of
> > > BC Manager
> > > Strange.
> > > Are you talking about the MIDI channels of individual
button/encoder
> > > definitions (as set on the "Standard output" tab, e.g. for CC
> > messages)?
> > > And what do you mean by "it always ends up being channel 16"
(and how
> > > have you tested that)?
> > > Mark.
> > > Messages in this topic (2) Reply (via web post) | Start a new
> > topic
> > > Messages | Files | Photos | Links | Database | Polls | Members |
> > Calendar
> > > MARKETPLACE
> > > From kitchen basics to easy recipes - join the Group from Kraft
Foods
> > > [The entire original message is not included]
> Messages in this topic (5) Reply (via web post) | Start a new
topic
