--- In bc2000@yahoogroups.com, "Uwe" <tonmanns@...> wrote:
> ok, I am running Cubase 5 under WinXP 32bit SP3, The BCR was in S1 mode when it occured ( I switched to S3 and S4 for testing, but only works partially)
> BCR is connected to I/O Port 8 of my MIDEX 8, the Faderport is connected via USB.
> The present setup is "Cubase Channel Control by Staffi" because it gives instant access to the EQs and sends( I eventually took out the parameters, that are present with the faderport to avoid the loopback symptom, but it still does not run smoothly).
> Switching to S4 helped, that the bcr parameters don´t influence the presonus amymore, but changing a volume value on the bcr ends up in a level jump when changing it on the presonus now, because it didn´t react on bcr movement before and starts from an other level. A bit complicated, isn´t it?!
The fact that the BCR was in S-1 probably explains your original feedback problem: as the diagram in Behringer's BCF/BCR manual shows, in S-1 anything sent to the BCR's MIDI IN is passed on to MIDI OUT A and B/THRU, which is undesired in a situation like yours, where Cubase is both at MIDI IN and MIDI OUT A (or B/THRU).
In a bidirectional connection with Cubase you should definitely use S-4 (and only MIDI OUT A, not B/THRU). (S-3 would be possible too, but only via MIDI OUT B/THRU.)
> I tried to disable the commands on the bcr that are not necessary and already covered by the presonus faderport, but Cubase still stops randomly.
Can you isolate this problem? Is it due to some MIDI feedback loop, or is it simply Cubase itself?
For instance: does this still happen when the BCR and/or Faderport are switched off?
It may indeed be a good idea to have EITHER the BCR OR the Faderport control a particular parameter, to avoid interference and jumps.
On the other hand, you might try to "integrate" the BCR and the Faderport via a setup with virtual MIDI ports (e.g. MIDI Yoke). You could then run MIDI-OX in the background to connect Cubase, the Faderport and the BCR in a triangle, where each of the three sends data to both the other devices. This would guarantee total parameter synchronization.
One other advantage of a setup via MIDI Yoke would be that you could insert a MIDI diagnostics program (e.g. MIDI-OX, MIDI Tools or BC Manager) into any connection between Cubase, the Faderport and the BCR, so that you can find out exactly which messages are sent when.
For instance, this might help you to find the cause of the random Cubase stops you're experiencing.
Hope this helps,
Mark.
