Programming BCR for the Dave Smith Evolver Desktop
2011-07-21 by longstrongturtle
Hey Folks, I downloaded the templates for the Evolver Desktop off this site and it seems like the templates use System Exclusive messages to change settings on the Evolver Desktop. All of the knobs in these templates go from 0-127 which doesn't make sense considering a lot of the parameters on the Evolver have different ranges, for example one parameter has a range of 0-200 on the Evolver and some have a range of 1-4.
I have an Evolver with the version 3.0 operating system which allows you to use MIDI Continuous Controller mapping, the previous versions only used System Exclusive messages which is what the presets on here were written for. Now what I am wondering is if I programmed a preset for the BCR-2000 using CC mapping instead of SysEx, would the LEDS move to their relative positions when I change presets on the Evolver Desktop? Currently, when changing patches on the Evolver Desktop, the knobs remain where they are on the BCR even if I have the midi out from the Evolver Desktop going into the midi-in on the BCR-200. That is what i'm most confused about and couldn't find a clear answer about. Thanks!
RE: [bc2000] Programming BCR for the Dave Smith Evolver Desktop
2011-07-21 by Greg Long
Not only do I have a preset for the Tetra on the BCR2000 but I am working on
software that loads the data from the current patch into the BCR2000 so you
can see the patch.
Right now only layer A is populated with data but is makes a big difference
to see the patch before editing it from the BCR.
All of the buttons and encoders are setup to use NRPN's to control the
Tetras parameters.
From: bc2000@yahoogroups.com [mailto:bc2000@yahoogroups.com] On Behalf Of
longstrongturtle
Sent: Wednesday, July 20, 2011 9:22 PM
To: bc2000@yahoogroups.com
Subject: [bc2000] Programming BCR for the Dave Smith Evolver Desktop
Re: Programming BCR for the Dave Smith Evolver Desktop
2011-07-21 by sghookings@tiscali.co.uk
Out of interest Greg, what framework are you choosing for your software?
VST, Java, c# ???
I always wanted to get into the Steinberg VST thang but to date have not managed to grasp the midievent examples.
Steve H
> can see the patch.
> Tetras parameters.
> longstrongturtle
RE: [bc2000] Re: Programming BCR for the Dave Smith Evolver Desktop
2011-07-21 by greg.web.dev@gmail.com
Hi Steve,
I am using the .NET 4 framework and im using the C# language.  If there
weren't so many parameters I would have been done long ago, but it will be
worth it when im done.
No VST version but that would be nice.
Greg
sghookings@...
Sent: Thursday, July 21, 2011 4:45 PM
Subject: [bc2000] Re: Programming BCR for the Dave Smith Evolver Desktop
VST, Java, c# ???
Steve H
--- In bc2000@yahoogroups.com <mailto:bc2000%40yahoogroups.com> , "Greg
on
you
> can see the patch.
difference
> Tetras parameters.
> From: bc2000@yahoogroups.com <mailto:bc2000%40yahoogroups.com>
[mailto:bc2000@yahoogroups.com <mailto:bc2000%40yahoogroups.com> ] On Behalf
Of
> longstrongturtle
> To: bc2000@yahoogroups.com <mailto:bc2000%40yahoogroups.com>
site
from
to
on
Sounds like you have gone down a similar route to me except I have a miniak.
For what it is worth my project is here
http://sourceforge.net/projects/miniaktools/
I have put raw binaries but the source code is git downloadable.
C# isn't my primary language so I made a load of mistakes. But this was meant to be a protohack. Anyhow I am (was until laptop BSOD - not my code!!) working on the class hierarchies. I simply didn't get (without explicit base keyword ) c# only calls default constrictors for derived objects.
Again you are probably a lot more savvy with c# but watch out for garbage collection on callback midi headers - soln - stick mem in a list somewhere else new memory is reclaimed - the midi API I added is unmanaged assemblies so it don't know the callback has a +1.
also you have to use invoke a lot if you want to update GUI from a thread (other than the GUI thread).
Apologies if you know all this already ... Not trying to make anyone suck eggs here.
Also with nrpn one has to be careful about recalling last known nrpn state to be midi compliant. I will shut up now. Have fun with your midi feedback. I just love watching my GUI move via my BCR controls. I did think about making a bias for the -ve NRPNs on miniak but for now I am just happy to have pretty much full control with GUI feedback. Now if only it would work under mono or gnu dot net :-(
Steve H
--- In bc2000@yahoogroups.com, greg.web.dev@... wrote:
> Hi Steve,
> Greg
> sghookings@...
> VST, Java, c# ???
> Regards
> Steve H
> on
> you
> > can see the patch.
> difference
> > Tetras parameters.
> Of
> > longstrongturtle
> site
> from
> to
> on
> the
2011-07-22 by Greg Long
Yeah updating the GUI is a pain having to Dispatch.Invoke every time. I am
taking a small break on it at the moment because I am learning some other C#
nuances but I hope to complete it soon. J
sghookings@...
Sent: Thursday, July 21, 2011 7:00 PM
eggs here.
Steve H
> Hi Steve,
> Greg
Of
> sghookings@...
> VST, Java, c# ???
> Regards
> Steve H
working
> on
> you
> > can see the patch.
> difference
> > Tetras parameters.
> Of
> > longstrongturtle
> site
> from
> to
BCR-2000
> on
> the
couldn't
2011-08-03 by massenmedium
Did you try my template?
It might be a little idiosyncratic, the best 1 page layout I could decide on for my purposes at the time, but the parameters are all mapped to the correct ranges etc.
Massimo
http://f1.grp.yahoofs.com/v1/wKg5Tv8swY2Z0NCon9jYb0omqlz9TQtwLzbWwOoXlWi7KdgkN2SFJ-v8yDhdlBgOcHFTZhx7mB25x37jxsOg110n9PUeMysYugIm/Presets/Massimo%27s%20BCR2000%20Evolver%20Map%201.1.zip
--- In bc2000@yahoogroups.com, "longstrongturtle" <pussycruncher69@...> wrote:
It was written for v3.0 Evolver as well by the way. You'll notice what's covered by CCs is quite limited.
Re: feedback of parms from the Evo, I think you need to make sure MIDI Xmit is enabled in the main settings.
Re: [bc2000] Re: Programming BCR for the Dave Smith Evolver Desktop
2011-08-03 by Robert Krueger
"Document not found"
Massimo
2011-08-04 by massimo
that link works fine here, might be your email client is splitting it.
or just grab the preset from the files/presets bit of this group.
Sent from Yahoo! Mail on Android
To: ;
Subject: Re: [bc2000] Re: Programming BCR for the Dave Smith Evolver Desktop
Sent: Wed, Aug 3, 2011 9:34:40 PM
Massimo
