Does my BCR2000 sound like it's broken?
2012-01-01 by oversampler
Hi I think I may have a problem with my BCR2000, the trouble is I'm not sure if it's something that is normal because it is a Behringer product & I should expect it to have quirky behaviour or if I should try & return it to where I bought it. I think that it probably is broken but I wanted to check here to see what other people thought. I'll try & describe what it is doing The Edit/Store/Exit/Learn buttons don't always do what they should when I press them, it can sometimes be difficult to enter Global Setup by holding Edit then pressing Store - the Edit button doesn't light up when pressed & sometimes the Learn button will light up as I press Store. Occasionally the display will show PANc Pressing Edit & turning any knob or pressing any button isn't taking me to any kind of edit mode. Pressing Learn & turning a knob sometimes takes me into Global Setup (the Edit & Store buttons light up when it does) The preset right button works ok, the left one is intermittent - usually I'm having to press the right one & turn encoder 1 to get back down the presets. Both of the buttons seem to function normally if I press store then try to select a destination preset. The LEDs around the knobs seem to light up in sympathy when other knobs in that row are being turned, with all the knobs in a row on a different setting all the knobs have a halo of lit LEDs surrounding them. When I have been trying to set these LEDs up I've always been going for the 1d option. I tried re-installing the firmware 1.10 to see if that would help but it hasn't made any difference. What do you think, does it sound like this is broken? I've only had it a couple of weeks, I bought it second hand. I could live with the LEDs being a bit funny but it's very frustrating trying to programme it with the Store/Edit/Learn/Exit buttons only working properly every now & then.
