--- In bc2000@yahoogroups.com, Rainer Keizer <rainer.keizer@...> wrote:
> How did you load the template? Did you use the Sysex or did you load the BC
> Manager preset?
> And can you explain what you mean with "in each encoder appear only 2
> values"?
> Do any values on the synth change when you turn a knob?
> The template uses MIDI channel 16 to send on, have you set your 8P to that
> channel? you can of course change this, which is easy when using the BC
> Manager.
yes, I use the channel 16, but in bcr2000, when I turn the knob, for modify, appears the value 49 as min, and 50 as max, and not the full range (0-100) for example.
