Err6 and Err22
Err6 and Err22
2012-11-30 by Uwe Jülich
hi all,
i get the two errors when trying to connect with reason. bc manager will also not recognize the bcr. is there any chance to find out what those error messages mean?
thx
Re: Err6 and Err22
2012-11-30 by Mark v.d. Berg
> messages mean?
See section 21.2 in "BC MIDI Implementation.pdf", available from http://home.kpn.nl/f2hmjvandenberg281/bc2000.html .
Error numbers 6 and 22 indicate problems with the BCL sequences:
In any BCL message sequence, each message has an internal index, and the BCF2000 and BCR2000 require these indexes to increment correctly (starting from 0).
So for instance if there is a split followed by a merge in the signal path, a (correct) sequence with indexes 0, 1, 2 ... would be received as 0, 0, 1, 1, 2, 2 - which the receiving BCF/BCR won't accept.
In any case there seems to be something fundamentally wrong about your connection setup.
Is your BCR in the correct Operating Mode (S/U-1/2/3/4)?
Hope this helps,
Mark.
AW: [bc2000] Re: Err6 and Err22
Thanks for you advice. In Windows XP all works as expected, I got this problems since Windows 7 64bit. Operation Mode is U-1. I'll test the unit again with XP tomorrow, so I can check it's ok.
thx
Von: bc2000@yahoogroups.com [mailto:bc2000@yahoogroups.com] Im Auftrag von Mark v.d. Berg
Gesendet: Freitag, 30. November 2012 22:45
An: bc2000@yahoogroups.com
Betreff: [bc2000] Re: Err6 and Err22
> messages mean?
Hope this helps,
Mark.
Re: Err6 and Err22
2012-12-01 by Mark v.d. Berg
Mode U-1 almost rules out message duplication via weird signal paths.
So more likely it's a problem related to the Windows 7 USB driver for the BCR (i.e. Behringer's 1.0.10 - I'm not sure about Microsoft's generic "USB Audio Device"):
In my experience this driver sometimes inserts a weird character in its MIDI I/O device names - although I'm not sure if this could cause "your" errors 6 and 22.
In any case, in BC Manager you should first make sure that the BCR's devices are checkmarked in the Options->"MIDI devices" dialog box.
Hope this helps,
Mark.
2012-12-01 by Uwe Jülich
I tested with xp, all works fine. In win 7 64bit - no chance. If anyone had similar problems and solved this, please help ;-)
thx
Gesendet: Samstag, 1. Dezember 2012 09:52
Hope this helps,
Mark.
RE: Err6 and Err22
2013-11-14 by <mkmannn@...>
Bump.
I am currently facing a similar, perhaps identical issue.
First post, btw:
I bought the bcr2000 couple days ago. I've tried dumping ableton's automap and using bcmanager and midiox to load presets for my alpha juno (all of which I've gotten from the files in this group) to no avail. I am running windows 7 64-bit.
Ableton behavior: blinking lights and Er22
BCmanager behavior: blinking lights, begins load status and stops immediately in the middle; if I send a sysx line by line Er22 comes up.
MidiOX behavior: seems to load successfully on the midiox software but nothing useful happens on the bcr
Has anyone resolved this problem? It is extremely frustrating. Any help at all would be tremendous.
Michael
thx
Von: bc2000@yahoogroups.com [mailto: bc2000@yahoogroups.com ] Im Auftrag von Mark v.d. Berg
Hope this helps,
Mark.
RE: RE: Err6 and Err22
After doing a little more research it turns out people are having issue with usb3 which im pretty sure ive got it hooked to. I'll check it...
