Hi Boogie
> Luckily for me, I was able to achieve the same results with a bit less
> work, because I use Logic Audio 5.5 - but I'm gonna work with yer
> solution as well!
Excellent!
Perhaps you might like to post your solution here so anyone else using
Logic (not me, I use Sonar) could benefit.
All the best
Royce
> > > On the BCR2000, I want assign ALL 32 rotary knobs to CC7.
> > > I want to send 16 of them (each on it's own MIDI channel 1-16) to
> > > MIDI OUT "A" to a 16 channel multitimbral synth module
> > Easy. Just use the font panel
> > > Then, I want to send 16 of them (each on it's own MIDI channel
1-16)
> > > to MIDI OUT "B" to another 16 channel multitimbral synth module
> > > This would allow me to control the individual volume on all the
MIDI
> > > channels on both modules.
> > > Can this be done?
> > Yes and no.
> > No. The BCR200 can't do it by itself as you can't pick the port to
> > output to as far as I know. Out is Midi out however you configure
> > unit so all the data will appear.
> > Yes. If you had a PC you could set the BCR to USB mode 3.
> > Then you could use MidiOx.
> > Set up the CC7 encoders as normal.
> > Set up a set of CC100 (any CC that you are not going to use) the
same way.
> > In MidiOx connect the BC USB to both the MidiA and MidiB of the BCR.
> > (View the Midi Port Routing window)
> > You then need to create 2 map files.
> > The first one just filters out CC100 on all channels using 'discard'
> > in the second drop down box.
> > Save the file as *NoCC100*
> > The second one does the same for CC7, but it also has a second line,
a
> > Map from CC100 to CC7 on all channels.
> > Save the file as *NoCC7*
> > Save both of these. NoCC7 and NoCC100, into the MidiOx Directory
> > (C:\Program Files\MidiOx - or where every you set up MidiOx)
> > In the Midi Port Routing window right click the small box on the
> > connecting line BCR USB to MidiA output and select properties.
> > Go to the "Map File" drop down box and pick NoCC100 .
> > When you turn CC7 encoder CC7 should come out, but when you turn a
> > CC100 encoder nothing should come out of MiidA
> > Do the same for MidiB connection but choose NoCC7. The CC100 encoder
> > should send out CC7 out the MidiB port and CC7 encoder should send
out
> > nothing.
> > If you need these MidiOx Map Files email me and I send them to you,
> > but they are fairly easy to set up.
> > Royce
