Squeaky Damper Pedal
2009-02-08 by manhattanboy100
Hi, I have a Mark IV and have two annoying problems with the damper
pedal: loud squeak and an overall rattle/vibration noise when the pedal
is depressed and held and the piano is played. Have always had this
issue but the problem has worsened over time. I have a call into the
dealer. I don't think its a simple adjustment. Thinking replacement
parts may be required. has anyone else experienced this? Carol? Thanks.
Ron
PS I have not been on this forum for a long time. There was some
discussion some time ago about migration to google groups but I guess
that did not happen? Thx.
Re: [disklavier] Squeaky Damper Pedal
2009-02-09 by athomik
If the pedal is noisy while you are playing, you should get your dealer to send a piano technician to have a look at the mechanism. Sometimes, just a little lubrication on the leather pads or linkages may work.
If the pedal is noisy while playing back (i.e. using the solenoids), there are a couple of adjustments on the solenoids which should cure the problem. Again, get your dealer to have someone look at it.
Either way, if the problem was apparent from new, it should be a warranty issue.
athomik
>Ron
>To Post a message to the group, send it to: disklavier@...
>To Post a private message to Todd Muncy, the group's founder and moderator, send it to:
>disklavier-owner@...
>To reach our group's web site go to:
>http://Yahoogroups.com/group/disklavier
>THINKING OF LEAVING THE GROUP?
>If you are thinking of unsubcribing because you are getting too much mail, go the the web site and change your email delivery option instead. That will fix the problem, while maintaining your access to the group. If you insist on leaving us completely send a blank email to:
>disklavier-unsubscribe@...
>Know someone who wants to join? Have them send a blank email to:
>disklavier-subscribe@... or give them this link:
>http://Yahoogroups.com/group/disklavier/join
>Yahoo! Groups Links
><*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/disklavier/
><*> Your email settings:
> Individual Email | Traditional
><*> To change settings online go to:
> http://groups.yahoo.com/group/disklavier/join
> (Yahoo! ID required)
><*> To change settings via email:
> mailto:disklavier-digest@yahoogroups.com
> mailto:disklavier-fullfeatured@yahoogroups.com
><*> To unsubscribe from this group, send an email to:
> disklavier-unsubscribe@yahoogroups.com
><*> Your use of Yahoo! Groups is subject to:
Re: Squeaky Damper Pedal
2009-02-09 by Mark Burby
I've not had the sqeaky pedal problem, but maybe the latter though not
sure if it is the same. When the piano was operating on playback, if
it operated the soft pedal, the piano keyboard would rattle violently.
A technician was able to make a minor tweak (tightened a bolt
somewhere I think) and solved the problem. Was quite worrisome on a
new MkIV but easily solved under warranty. Once again, not sure if
this is the same problem you're experiencing.
-- Mark
