Disklavier in MX100A upright
2009-06-01 by iudkuy
Hi everyone
This is my first post. I have recently purchased a G2 disklavier and was going to sell my upright MX100A to a friend. So of course it has suddenly stopped working after so many years.
The first symptom was that it said "press stop key" as it usually does when unused for a while and pressing the stop key elicited no response. A turn off and turn back on produced a double zero display with just one line of boxes in the text display. It will not proceed past this point. I tried doing a diagnostic by pressing L and R buttons while turning it on but the result was the same.
What doesn't seem to be happening is that the floppy drive is silent making me think that that has failed causing this freeze.
Can you still get floppy drives of this antiquated technology or is there some way of updating the input source. I normally run the Disklavier from a PC anyway but need the floppy working for the MIDI signal to be accepted.
What is the best way round this problem?
Peter B
Re: [disklavier] Disklavier in MX100A upright
2009-06-01 by Carol Beigel
There is a way to circumvent the need for the Floppy Disk drive when
connected to a PC.  On your model, you have a MIDI button all the way to the
right.  Press the MIDI button, simultaneously with the Record and Power
buttons to boot the Disklavier.  See if it works.  You probably need a new
floppy drive.
Carol Beigel
To: <disklavier@yahoogroups.com>
Sent: Monday, June 01, 2009 7:19 AM
Subject: [disklavier] Disklavier in MX100A upright
> Hi everyone
> accepted.
> Peter B
> To Post a message to the group, send it to:   disklavier@...
> To Post a private message to Todd Muncy, the group's founder and
> moderator, send it to:
> disklavier-owner@...
> To reach our group's web site go to:
> http://Yahoogroups.com/group/disklavier
> THINKING OF LEAVING THE GROUP?
> If you are thinking of unsubcribing because you are getting too much mail,
> go the the web site and change your email delivery option instead.  That
> will fix the problem, while maintaining your access to the group.  If you
> insist on leaving us completely send a blank email to:
> disklavier-unsubscribe@...
> Know someone who wants to join?  Have them send a blank email to:
> disklavier-subscribe@... or give them this link:
> http://Yahoogroups.com/group/disklavier/join
> Internal Virus Database is out of date.
> Checked by AVG - http://www.avg.com
> Version: 8.0.138 / Virus Database: 270.12.39/2134 - Release Date:
> 5/25/2009 6:14 PM
2009-06-02 by athomik
There could be a couple of reasons why you have a problem.
The disk drive would be the most likely culprit, but the "Push Stop Key" message could also indicate a logic fault, which could mean a new CPU circuit board. It could also indicate that the key/pedal drive power is off due to a fault on the key drive or pedal drive.
athomik
>floppy drive.
>Carol Beigel
>----- Original Message -----
>From: "iudkuy"
>To:
>> Hi everyone
>> accepted.
>> Peter B
>> Yahoo! Groups Links
>> 5/25/2009 6:14 PM
>To Post a private message to Todd Muncy, the group's founder and moderator, send it to:
>If you are thinking of unsubcribing because you are getting too much mail, go the the web site and change your email delivery option instead. That will fix the problem, while maintaining your access to the group. If you insist on leaving us completely send a blank email to:
>Yahoo! Groups Links
><*> To visit your group on the web, go to:
> http://groups.yahoo.com/group/disklavier/
><*> Your email settings:
> Individual Email | Traditional
><*> To change settings online go to:
> http://groups.yahoo.com/group/disklavier/join
> (Yahoo! ID required)
><*> To change settings via email:
> mailto:disklavier-digest@yahoogroups.com
> mailto:disklavier-fullfeatured@yahoogroups.com
><*> To unsubscribe from this group, send an email to:
> disklavier-unsubscribe@yahoogroups.com
><*> Your use of Yahoo! Groups is subject to:
