Changing Patterns on MD via MnM
2004-03-04 by mackroscopic
I have a question on how I should be changing patterns on the MachineDrum from the MonoMachine. On the MonoMachine, I use a midi track to send a note to change the pattern on the MachineDrum to the one I want (i.e. A4 to switch to pattern A1). The problem I'm having is when the MachineDrum loops, it tries to change back to the previous pattern it was on. This can cause a sort of 'hiccup' if the kits are different. Is there a way I can change the pattern on the MachineDrum 'permanently' from the MonoMachine? (Sorry if i missed a solution in the archives, I tried looking).
