To: emax@yahoogroups.com
Sent: Thursday, May 27, 2004 12:11 AM
Subject: [emax] Re: Formatting Zip Disk (Emax 1 se hd plus)
Thanks very much, it worked perfectly. The first time I switched to
a different
scsi id, I had to press the number twice. Now it only needs to be
pressed
once. Now I think I'll copy all my data to Zip and disconnect the
noisy internal
hd. Thanks again,
Peter
> Does your emax have an external scsi port? Is your zip hooked up
to it?
> If so, you need the Emax Plus OS, if you have that, you hold down
transpose button and you see the scsi ID at zero (this specifies the
internal
Hard Drive) Press whatever SCSI ID the zip is twice while the
transpose
button is held and it should change if the device is connected
properly. Once
it is something other than zero, the format HD command will format
the zip.
This is a much quicker format than the internal HD.
> A good way to test if you have the Plus OS is to hold the transpose
button,
if it says SCSI ID under transpose, you have plus and can proceed.
> I am not sure why I have to hit the number twice, but for some
reason it
doesn't register when I only press it once.
> From: bassmeter
> Sent: Wednesday, May 26, 2004 11:15 PM
> Subject: [emax] Formatting Zip Disk (Emax 1 se hd plus)
> I've got an Emax 1 hd se plus that currently has an internal hard
> drive. I would
> like to format a Zip disk connected to the external scsi
connection.
> I don't think
> there is a way to specify which hd to format -the internal hd, or
> zip. Looks
> like the existing internal drive is the only one visible to the
Emax.
> 1) To format an external Zip disk would I have to disconnect the
> internal hd,
> and boot the Emax from floppy? Select format hd.
> 2) I also have an internal scsi Zip drive sitting around and
wanted
> to know if
> it's difficult to connect the wires if it were to be put in place
of
> my
> existing internal
> hd?
> Thanks,
> Peter
> http://www.silveriafamily.com
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> a.. To visit your group on the web, go to:
> http://groups.yahoo.com/group/emax/
> b.. To unsubscribe from this group, send an email to:
> emax-unsubscribe@yahoogroups.com
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
> Outgoing mail is certified Virus Free.
> Checked by AVG anti-virus system (http://www.grisoft.com).
> Version: 6.0.680 / Virus Database: 442 - Release Date: 5/9/04
ADVERTISEMENT
Yahoo! Groups Links
Version: 6.0.680 / Virus Database: 442 - Release Date: 5/10/04
