I can't answer that.. Rob at Emulator Archive has the lowdown on the actual internal
parts.
On 5 Oct 2004 at 16:55, Micke Askernäs spoke unto me:
> Thanks for your answers, John...
> However, one quick question:
> How powerful is/was the original Emax power supplys?
> since mine were fried, i managed to fit two 80W supplys i bought 12
> years ago and never used into the each of my emaxes, and it seems to
> have worked just fine since then, and since it has basically the same
> specifications (a few extra coords that i dont use, but othwerwise
> same Voltage and Ampere on the outputs)..
> hopefully, this 80W should be more than sufficient to run a zipdrive
> on, escpeicllay when i remove both floppy and harddrive...
> //Micke
> On Tue, 05 Oct 2004 10:39:14 -0400, John Silveria wrote
> > On 5 Oct 2004 at 15:18, Micke Askernäs spoke unto me:
> > > One of these emaxes also came equipped with an internal hd, but as
> > > it is closing in on 20 years old, I'm thinking of putting in an
> > > old scsi zip 100 drive into it instead and all that..
> > Remember if you are not going to do the external Zip Mod you will
> > need to
> make sure
> > the new power supply can handle the Zip, the original power supply
> > can't.
> > > BUT ... my problem is: how do i transfer the os from the harddrive
> > > (or from diskette) to the zipdrive that i was plannign on making
> > > internal?
> > When you run the format command from any bootable media (floppy or
> > hard
> drive) it
> > automatically copies the OS as part of the process.
> > > Also, if i've read it correctly on emulatorarchive, all i really
> > > need to do is take out the harddrive, and set my zipdrive as SCSI
> > > id 100 and it should hopefully try to boot from the zipdrive
> > > instead..
> > If you have the Zip set to the same ID as the hard drive then yes,
> > it will
> try to boot from
> > the SCSI ID assigned to the hard drive first.
> > > BUT .. the emax doesnt support larger drives than 20 MB ... so ...
> > > i take it i need to format the zipdisk into a format the emax can
> > > understand..
> > The only way to format a srive for Emax use is with the Emax itself,
> > it has
> it's own
> > proprietary format scheme. It will ignore anything beyond the 20Mb
> > it can
> format.
> > > of course, to make matters harder, the old emaxes i was given had
> > > been given a rather crude paint job, and this none of the old menu
> > > buttons are visible, so i really have no idea what button does
> > > what at this point .. ;)
> > Download the manual in pdf format from wither my site or the
> > Emulator
> Archive. It's not
> > as good as having the menu on the unit itself, but what can you do!
> > > I am refurbishing the emaxes for live use with my band .. i'll
> > > post images when the first one is ready ;)
> > > in the mean time, i'd appreciate a little help .. also .. where
> > > can i change what midi channel the emax is transmitting on?
> > I can't quite remember it's been a long time, but it should be
> > somewhere in
> the Master |
> > Special menu. Try pressing Master then using the slider to see the
> > name of
> all the
> > menus, I think it might be Master | 0 (Special) | 2 Midi Master ..
> > but hat
> could be wrong
> > too ..
> > John Silveria II
> > AIM & Yahoo! Messenger: EmaxJS
> > MSN: emaxjs@...m
> > The Silveria Family Website & Emax and Emax II User's Group
> > http://www.silveriafamily.com
> > Emax and Emax II User's Group Website
> Yahoo! Groups Sponsor
> ADVERTISEMENT
> - Yahoo! Groups Links > * To visit your group on the web, go to: >
> http://groups.yahoo.com/group/emax/ > * To unsubscribe from this
> group, send an email to: > emax-unsubscribe@yahoogroups.com > * Your
> use of Yahoo! Groups is subject to the Yahoo! Terms of Service.
> --------------------~--> Music that listens to you. LAUNCHcast. What's
> in your mix? http://us.click.yahoo.com/akrq7C/FARHAA/n1hLAA/QnLolB/TM
John Silveria II
MSN: emaxjs@...
