--- In emax@yahoogroups.com, "elmacaco" <elmacaco@h...> wrote:
The hard drive I have is a Quantum Pro 50mb and while acoustically
it's not too bad, the problem
is the transmitted output noise. Turning the monitors up reveals
this, more so than any other
equipment I have.
It's down to the whirr and whine.
It's connected via a plate to the outside casing and after
disconnecting the power to it
the whirr ceased, but not the whining.
I then disconnected the scsi cable and lifted it outside the case.
The whining stopped then
as well.
It seems the whine is caused by contact of the plate to the outside
casing.
So, some insulation tape and rubber grommets cured that.
I haven't found a way to cure the whirr but it's definetely more
acceptable now.
As regards the filter, yes, the 2 pole sounds a lot closer than the
defaulted 4 pole.I compared it with the original source from the Emax
as well and the Esynth translation is better than the Emax II,
strange !
Lyn
> Booting from floppy is not the end of it, the emax then accesses
the floppy to perform different functions. I could never disconnect
the HD in mine for that reason alone, it would slow me down more.
> The noise from the HD is loud, but it varies between units (and
perhaps HD's?) mine's not the loudest I've heard but not much softer.
> I think just removing power to it should do it. maybe remove the
internal scsi cable as well, but that might not be necessary.
> I like the external zip a lot too. maybe there's a way to get a
internal zip drive in an enclosure to make it external that then can
be set to SCSI ID 0 ??
> From: grenham7651
> To: emax@yahoogroups.com
> Sent: Saturday, December 17, 2005 4:47 PM
> Subject: [emax] Emu Filter differences - fan noise - HD removal
> I've just imported some EMAX II samples into the Esynth, rev
4.62,
> and found some sounds haven't translated too well.
> Seems to be the filter settings that suffer. The Esynth's 4 pole
> filter and Q settings, looking like they translated well, with a
> precise frequency rather than a 0-120 Fc number, sounded thinner,
> lacking weight and bottom end. Although there's a good selection
of
> filters, I haven't been able to exactly recreate the original
sound.
> Any theories on this ?
> Has anybody been bothered by the noise of the Esynth rack's fan ?
> It's not just the whirring but the whining as well. I replaced
mine
> with a Papst but didn't get much improvement, so have
disconnected
> it. There's a lot of free space inside and ventilation on the
power
> supply casing so I'm hoping it should be OK.
> One final question, regarding removing or disconnecting Emax 1´s
hard
> disk, is it an easy job disconnecting it internally ?
> Have other users been bothered about the output level of HD
noise ?
> I have an external zip that I prefer to use but will I have to
boot
> from a floppy as the zip is configured for scsi 5 or 6 only.
> regards
> Lyn
> http://www.silveriafamily.com
> YAHOO! GROUPS LINKS
> a.. Visit your group "emax" on the web.
> b.. To unsubscribe from this group, send an email to:
> emax-unsubscribe@yahoogroups.com
> c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
