Re:Re:Troubles
2001-11-19 by ashley spradlin
Thanks for the suggestions, Skip. Help is much appreciated. > continuity check on the wires to the connector to the main board. Here my technical ignorance rears its head. I've no idea what "continuity check on the wires . . . " means. > the users manual there is a procedure to re-callibrate the Pitch > Wheel follow it closely. Does your pitch change when the Emax II > is slave to another Keyboard (Midi)? Try it and see. Tried the re-calibration numerous times to no avail. Haven't tried using midi, but the pitch works fine when I re-assign it to the right (modulation) wheel. Small comfort, though, because it doesn't spring back to the middle to keep in tune. Ashley ______________________________________________________________________________ Send a friend your Buddy Card and stay in contact always with Excite Messenger http://messenger.excite.com
