Cool, thanks Ted... I might give that a try when I have a free afternoon.
Brooks
On Mon, Feb 2, 2009 at 8:58 PM, Ted Summers <djtbs1@...> wrote:
> Another idea might be if those ICs are socketed on the analog board,
> to move a working voice to a non-working section and see if that voice
> now works.
> That might help determine if it is an IC.
> Just a thought, I don't have my Emax apart, so I am just guessing.....
> Regards,
> Ted
> On Feb 2, 2009, at 6:03 PM, jammie.emma wrote:
> --- In emax@yahoogroups.com <emax%40yahoogroups.com>, Brooks Mosher
> <brooksmosher@...> wrote:
> > this could be a number of things you could have a filter amp ic down
> or the sample and hold chip is playing up these are 2300 ic
> if it is these upgrade to smpo8 as these are the replacement and
> have a faster slew rate equals snappier envelopes.
> or it could be the e chip if its this then you cant get these no
> more unless you get a broken emax1
> also check the decoupling caps if these go down you can get all
> sorts of problems from distortion to audio drop outs
> you will need a oscilloscope to see this though.
> jammie
> > Maybe someone on the list can help me here.
> > So I got a new floppy drive working (thanks Ted) on my Emax and I'm
> *just*
> > now getting around to using EMXP and loading up presets. It's a
> Teac Slim
> > Floppy and looks pretty slick in the rack as it matches somewhat
> closely the
> > color of the Emax Chassis. I've got room for another 3.5" drive and
> was
> > going to put a Zip100 in only to find out that they are a fraction
> wider
> > than the slot I have to work with. Ugh. (anyone else run into
> problems
> > mounting a Zip100 drive per it's width?).
> > Anyways, my question that is bothering me at the moment::
> > Is it possible that a few of the voices could go out on these? I
> seem to
> > have limited polyphony on mine (although I haven't confirmed this
> 100% as
> > I'm not using my own presets and there could be layered samples).
> Anyways I
> > checked and none of the voices are disabled in the Master section,
> and
> > nothing distorts... it just seems like I'm not getting 8 note
> polyphony.
> > Any insight from the group? I definitely need to test this for sure
> with a
> > preset that uses 1 sample only mono.
> > Thanks and much respect to the people on this forum,
> > Brooks
> > [Non-text portions of this message have been removed]
