Emax II HD
2009-07-16 by Louis van Dompselaar
As my Emax II harddisk is slowly dying, what are the experiences of Emax II owners wrt replacements? I currently have a Conner CP-3100 (105MB). I already found a 2GB Quantum in my own collection of old drives, but the Emax doesn't like that very much. Are there any larger drives that can be made to work?
2009-07-16 by Ted Summers
Some older HD have a jumper to set it to 512MB limit. Maybe that would make it work- if ti has that option? Just a thought. regards, Ted On Jul 16, 2009, at 7:05 AM, Louis van Dompselaar wrote: As my Emax II harddisk is slowly dying, what are the experiences of Emax II owners wrt replacements? I currently have a Conner CP-3100 (105MB). I already found a 2GB Quantum in my own collection of old drives, but the Emax doesn't like that very much. Are there any larger drives that can be made to work? [Non-text portions of this message have been removed]
2009-07-16 by el macaco
I had a lot of luck opening my EMAX I's HD up and manually spinning the disk then formatting. if the problem is that the disk isn;t spinning. Now I have a CF card reader in an external box set for scsi ID 0 and I just the the HD stop spinning without restarting. After long time of not powering up, it will not spin again, and a few slaps on the top can make it start again! Worked for years like that, but not a permanent solution. To: emax@yahoogroups.com
From: djtbs1@... Date: Thu, 16 Jul 2009 07:18:31 -0700 Subject: Re: [emax] Emax II HD Some older HD have a jumper to set it to 512MB limit. Maybe that would make it work- if ti has that option? Just a thought. regards, Ted On Jul 16, 2009, at 7:05 AM, Louis van Dompselaar wrote: As my Emax II harddisk is slowly dying, what are the experiences of Emax II owners wrt replacements? I currently have a Conner CP-3100 (105MB). I already found a 2GB Quantum in my own collection of old drives, but the Emax doesn't like that very much. Are there any larger drives that can be made to work? [Non-text portions of this message have been removed] _________________________________________________________________ Windows Live� SkyDrive�: Get 25 GB of free online storage. http://windowslive.com/online/skydrive?ocid=TXT_TAGLM_WL_SD_25GB_062009 [Non-text portions of this message have been removed]
2009-07-16 by Elk Latham
You should be able to use any Quantum drive that came out of an old SCSI based mac up to 500 Mb. Maybe up to 1GB will work. I ditch my hard drive and floppy drive for an old SCSI based CF writer/reader that I installed internally where the floppy drive was. I then use EMXP to format and create banks on the CF cards. check this out. http://www.scsiforsamplers.com/ Elk ________________________________
From: Louis van Dompselaar <louis@...> To: emax@yahoogroups.com Sent: Thursday, July 16, 2009 7:05:28 AM Subject: [emax] Emax II HD As my Emax II harddisk is slowly dying, what are the experiences of Emax II owners wrt replacements? I currently have a Conner CP-3100 (105MB). I already found a 2GB Quantum in my own collection of old drives, but the Emax doesn't like that very much. Are there any larger drives that can be made to work? [Non-text portions of this message have been removed]
2009-07-17 by Louis van Dompselaar
The problem is that the disks starts spinning and then stops again. It usually starts working after 10-20 attempts, but it's too slow to be able to boot off of it. The Emax will give up before the disk is ready. I used to have to hit my Amiga A1200 to get the drive to spin. Got used to that pretty quickly and used it for years like that. I found someone close by though that appears to have a stack of 52MB Quantum drives. Going to check those out tonight. Op 16 jul 2009, om 17:16 heeft el macaco het volgende geschreven:
> > I had a lot of luck opening my EMAX I's HD up and manually spinning > the disk then formatting. if the problem is that the disk isn;t > spinning. Now I have a CF card reader in an external box set for > scsi ID 0 and I just the the HD stop spinning without restarting.
Yes, that would be the preferred solution. However, at $89+$30 shipping to Europe, it's not worth it, especially since I'm repairing to sell (and they sell for around $200-$250 over here).
> I ditch my hard drive and floppy drive for an old SCSI based CF > writer/reader that I installed internally where > the floppy drive was. I then use EMXP to format and create banks on > the CF cards.
