Emax
Hallo to the Emax community
2009-08-03 by midimal_music
Glad to have found this buzzing community after owning an emax for many years.I'm now in the process of looking into whether I can SCSI up my Emax 1 SE which is something I've thought about doing a few times but was previously thwarted due to it not having the 5380 chip.I'm hoping this can be solved now with a kit from Ted Summers.
I also need a back light and was wondering if anyone could point me in the direction of obtaining one, specific part number ? I saw an HD44780 20X4 Character LCD Display with LED backlight on ebay and was wondering if I could use that?
Thanks for any advice on this.
Bob K
Re: [emax] Hallo to the Emax community
2009-08-03 by jammie
no you cant but be wary i had a back light from the german company and the cathode and anode was backwards so it shon on the wrong side
he told me to turn it round but i now that it dont work that way and i did as he said and it did not light at all
i changed mine to a led but the problem is that its 7 mm bigger and so you dave to extend all the buttons so that they fit the panel i also had to extend the pins for the volume and data sliders
  To: emax@yahoogroups.com
  Sent: Monday, August 03, 2009 4:07 PM
  Subject: [emax] Hallo to the Emax community
  Bob K
  Checked by AVG - www.avg.com
  Version: 8.5.392 / Virus Database: 270.13.42/2279 - Release Date: 08/03/09 05:57:00
Re: Hallo to the Emax community
2009-08-04 by midimal_music
thanks for your reply jammie,i realize i should have done my research a bit better before asking that backlight question.
 acctually i remembered i had a backlight (just the plastic strip part) that i orderd some time ago from a guy in canada... and have had a similar experience to you trying to fit it. it lights up nice and blue but that's it, blank.......everything else sounds like it's working ok, disc loads up etc, just wondering how to proceed from here....???
>   ----- Original Message -----
>   From: midimal_music
>   Bob K
Re: [emax] Re: Hallo to the Emax community
2009-08-05 by jammie
is it a keyboard or rack on the rack there is a negive voltage inverter so the screen can be seen from above you can adjust the contrast by turning the trim pot on the screen pcb
  Sent: Wednesday, August 05, 2009 12:03 AM
  Subject: [emax] Re: Hallo to the Emax community
  > From: midimal_music
  > Bob K
  Version: 8.5.392 / Virus Database: 270.13.43/2281 - Release Date: 08/04/09 05:57:00
2009-08-05 by Bob King
it's the keyboard version, so it looks like i'm going to have to try and track down another complete back light unit
--- On Wed, 5/8/09, jammie <jammie.emma@...> wrote:
Subject: Re: [emax] Re: Hallo to the Emax community
Date: Wednesday, 5 August, 2009, 4:02 AM
  To: emax@yahoogroups. com
acctually i remembered i had a backlight (just the plastic strip part) that i orderd some time ago from a guy in canada... and have had a similar experience to you trying to fit it. it lights up nice and blue but that's it, blank....... everything else sounds like it's working ok, disc loads up etc, just wondering how to proceed from here....???
  > From: midimal_music
  > Bob K
RE: [emax] Re: Hallo to the Emax community
2009-08-05 by el macaco
Wait there is a contrast knob?  Wow!
Do you have to remove the PCB to get at it, or is there a trimmer hole?
Thanks Jammie!
Date: Wed, 5 Aug 2009 03:02:18 +0100
> From: midimal_music
> Bob K
Get free photo software from Windows Live
http://www.windowslive.com/online/photos?ocid=PID23393::T:WLMTAGL:ON:WL:en-US:SI_PH_software:082009
you have to remove the front panel pcb to access the trim pot its a shame that they never added it in software or add a trimpot nob on the front you can change it to a longer nob contol but would have to drill front panel
  Sent: Wednesday, August 05, 2009 2:34 PM
  Subject: RE: [emax] Re: Hallo to the Emax community
  Thanks Jammie!
  > From: midimal_music
  > Bob K
  Version: 8.5.392 / Virus Database: 270.13.44/2283 - Release Date: 08/05/09 05:57:00
2009-08-05 by Robert Cary
On mine, beneath where the backlight is mounted onto the pcb, it reads "In case of emergency break glass!"
--- On Wed, 5/8/09, jammie <jammie.emma@blueyonder.co.uk> wrote:
> From: jammie <jammie.emma@...>
> To: emax@...m
> Date: Wednesday, 5 August, 2009, 3:21 PM
> front panel
>   From: el macaco
>   Thanks Jammie!
>   From: jammie.emma@...
> screen pcb
>   From: midimal_music
> question.
> here....???
> at all
>   > From: midimal_music
> could use that?
>   > Bob K
> removed]
> removed]
> removed]
> http://www.silveriafamily.comYahoo! Groups Links
>     mailto:emax-fullfeatured@yahoogroups.com
they all say that its emu,s funny humor they have reference to star wars as well as beyond the thunder dome
  Sent: Wednesday, August 05, 2009 4:15 PM
  > front panel
  >   From: el macaco
  >   Thanks Jammie!
  > screen pcb
  >   From: midimal_music
  > question.
  > here....???
  > at all
  >   > From: midimal_music
  > could use that?
  >   > Bob K
  > removed]
  > removed]
  > removed]
2009-08-06 by emax_dx5
Just point that not all emaxes have that trimmer for lcd contrast. I have got two Version 2 Rev C boards, one of those has the pot, and the other has just a fixed resistance.
Regarding the backlight, it is an Electroluminiscent sheet. I've bought it in an electronics dealer and did mine. I've fixed my three emaxes backlight and now they shine as new. (electronics skill required for this, there are lot of volts under the screen for the EL sheet.
> Bob K
2009-08-06 by Bob King
Thanks for the info,
As the backlight PCB on my emax doesn't seem to have the trimmer could anyone suggest why I'm not getting any characters on the backlight when I turn the unit on. As I wrote before-it lights up fine.
Do the specifications on these electroluminescent sheets vary and could it be I've received and fitted the wrong type ?
Thanks
Bob
Date: Thursday, 6 August, 2009, 11:07 AM
> Bob K
2009-08-06 by jammie
its the lcd thats broken check that your getting 5v on the lcd and -4.7 volts on pin 3
  Sent: Thursday, August 06, 2009 6:01 PM
  Thanks
  Bob
  > Bob K
  Version: 8.5.392 / Virus Database: 270.13.45/2285 - Release Date: 08/06/09 05:57:00
2009-08-07 by emax2@...
Does anyone know a reliable source for the Electroluminiscent sheet?
Sent: Thursday, August 6, 2009 2:11:39 PM GMT -06:00 US/Canada Central
Thanks
Bob
> Bob K
2009-08-07 by jammie
you still should get letters come up on the screen even with out the light strip if you have no letters its not the strip thats at fault
  Sent: Friday, August 07, 2009 2:44 AM
  Thanks
  Bob
  > Bob K
2009-08-10 by Bob King
I'm looking for to replace the piece of glass on the back light, can anyone suggest where I could get one?
Thanks
Bob
Date: Friday, 7 August, 2009, 3:44 AM
Thanks
Bob
> Bob K
http://www.silveria family.comYahoo! Groups Links
2009-08-10 by jammie
there is no glass on the back light the back light is a el strip it works of a 100 vac around about 400hz frequency
if you need a glass thats the lcd you have to replace the lcd circuit board as its non repairable if it cracks or smashed or scratched it needs changing
you have to be very carefull when putting in a el strip becuase it can scratch the lcd under surface
  Sent: Monday, August 10, 2009 12:34 PM
  Thanks
  Bob
  Thanks
  Bob
  > Bob K
  Version: 8.5.392 / Virus Database: 270.13.49/2293 - Release Date: 08/09/09 18:10:00
thanks jammie, yes; sorry that's what i meant. it's the piece of glass that fits into the lcd which is badly scratched, does anyone know where i could get a replacement.
thanks
Date: Monday, 10 August, 2009, 1:55 PM
Thanks
Bob
Thanks
Bob
> Bob K
The part number written on the PCB is  H-DM16216H-2 but i've only manged to find them at companies which sell as bulk orders
Date: Monday, 10 August, 2009, 2:59 PM
thanks
Thanks
Bob
Thanks
Bob
> Bob K
rs componants
  Sent: Monday, August 10, 2009 1:59 PM
  thanks
  Thanks
  Bob
  Thanks
  Bob
  > Bob K
Thanks, is this the right one? http://uk.rs-online.com/web/search/searchBrowseAction.html?method=searchProducts&searchTerm=%09532-6379&x=26&y=14
Date: Monday, 10 August, 2009, 3:23 PM
                  rs componants
thanks
Thanks
Bob
Thanks
Bob
> Bob K
no thats a bottom termination you need the side termination
RS Stock No.214-3244 ManufacturerPowertip Manufacturers Part No.PC1602AR-H Catalogue page 2 - 3495
this is the one you want they also sell the sheet but you will have to cut it yourself to size make sure you cut the right cathode and anode pair for itr to light the right way round
the el sheet comes  in various colours from red to blue and yellow and green orange
  Sent: Monday, August 10, 2009 4:20 PM
  rs componants
  thanks
  Thanks
  Bob
  Thanks
  Bob
  > Bob K
much appreciated jammie
Date: Monday, 10 August, 2009, 5:30 PM
RS Stock No.214-3244 ManufacturerPowerti p Manufacturers Part No.PC1602AR- H Catalogue page 2 - 3495
Thanks, is this the right one? http://uk.rs- online.com/ web/search/ searchBrowseActi on.html?method= searchProducts& searchTerm= %09532-6379& x=26&y=14
rs componants
thanks
Thanks
Bob
Thanks
Bob
> Bob K
