Emax
Re: [emax] Re: Emax II RIP? (not!)
2009-11-27 by Daniel Baum
Hi all,
Mine seems to be fixed! Installing the PSU was literally a 5-minute job, and the Emax II turned on and played when I tested it.
I may have been imagining it, but it also seemed quieter. Possibly the old PSU was making a noise.
I'll send pictures later on.
Highly recommended.
D.
  Got mine today! Very fast shipping from Miami to Sweden I must say,
  1 week. =) I will try to install it in my Emax II tonight.
  Hope its just to replace the old PSU without modifications
  to this "new" unit. My old PSU is actually working fine. Its just that
  whining sound that comes when i load from the HD that worries me.
  So if anyone wants to buy my old PSU and fix it up or something you can contact me.
  --- In emax@yahoogroups.com, "Daniel Baum" <daniel@...> wrote:
  > Mine arrived yesterday. All I have had time to do was open the box and look at it.
  > I don't foresee any problems installing it. I will mark all of the plugs to make sure I plug them in the right way.
  > I probably won't have time to do it until the weekend.
  > I will post photos etc when I do it.
  > Daniel
  > My PSU was shipped today so I will recieve it in a week or two.
  > Please share your install procedure and tell us how it goes
  > there is anything else to do then to "just replace" it with the old one =)
  > --- In emax@yahoogroups.com, "dbaum0000" <daniel@> wrote:
  > > --- In emax@yahoogroups.com, "drifter7508" <drifter7508@> wrote:
  > > > I just ordered one yesterday for my Emax II from that company.
  > > > I will let you all know how it goes.
  > > I also ordered one and I'm supposed to be receiving it today.
  > > Hopefully my Emax II should be back up and running quite soon.
  > > Is there anything I should know about before installing it? According to the seller it is practically identical to the original and a simple swap.
  > > Daniel
PS.
I forgot to add in my previous message: Thanks to whoever it was that (apparently) correctly diagnosed my problem!
Daniel
  To: emax@yahoogroups.com
  Sent: Friday, November 27, 2009 3:21 PM
  Subject: Re: [emax] Re: Emax II RIP? (not!)
  Hi all,
  Highly recommended.
  D.
  > Daniel
  > > Daniel
2009-11-27 by drifter7508
Great to hear that all worked out for you Daniel!
Was it just to replace to the PSU straight off?
Just replace and reattach the cables?
> PS.
> Daniel
>   ----- Original Message -----
>   From: Daniel Baum
>   Hi all,
>   Highly recommended.
>   D.
>   > Daniel
>   > > Daniel
Yes. it was that simple.
Here are some pics:
The old PSU marked up. It would actually have been quite difficult to connect it wrongly but better safe than sorry:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/Old%20PSU%20in%20Emax.jpg
No PSU:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/PSU%20gone.jpg
And the new one in. It is very slightly bigger than the old one:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/New%20PSU%20in.jpg
Back together:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/back%20together.jpg
Back home:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/back%20home.jpg
These are some close-ups of the old PSU from which you may or may not be able to see what was wrong with it:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/Old%20PSU%201.jpg
This looks pretty horrible:
http://www.type34.info/temp/My%20equipment/Emax%20PSU/Old%20PSU%202.jpg
http://www.type34.info/temp/My%20equipment/Emax%20PSU/Old%20PSU%203.jpg
http://www.type34.info/temp/My%20equipment/Emax%20PSU/Old%20PSU%204.jpg
Regards to all,
D.
  Sent: Friday, November 27, 2009 4:11 PM
  Subject: [emax] Re: Emax II RIP? (not!)
  > PS.
  > Daniel
  > From: Daniel Baum
  > Hi all,
  > Highly recommended.
  > D.
  > > Daniel
  > > > Daniel
Great pictures Daniel! Piece of cake then.
Thx! Gonna install mine now after work.
> Here are some pics:
> No PSU:
> Back together:
> Back home:
> Regards to all,
> D.
>   From: drifter7508
>   > PS.
>   > Daniel
>   > From: Daniel Baum
>   > Hi all,
>   > Highly recommended.
>   > D.
>   > > Daniel
>   > > > Daniel
Just installed mine. Sounds much better now. No whining sound
from the PSU. =) Took 3 minutes to install.
> > Here are some pics:
> > No PSU:
> > Back together:
> > Back home:
> > Regards to all,
> > D.
> >   From: drifter7508
> >   > PS.
> >   > Daniel
> >   > From: Daniel Baum
> >   > Hi all,
> >   > Highly recommended.
> >   > D.
> >   > > Daniel
> >   > > > Daniel
You're quicker than me then;~)
Glad to hear it worked out.
D.
  > > Here are some pics:
  > > No PSU:
  > > Back together:
  > > Back home:
  > > Regards to all,
  > > D.
  > > From: drifter7508
  > > > PS.
  > > > Daniel
  > > > From: Daniel Baum
  > > > Hi all,
  > > > Highly recommended.
  > > > D.
  > > > > Daniel
  > > > > > Daniel
2009-11-28 by rpcfender
The electro caps looked stuffed, which is typical for the age and they are the first port of call in a rebuild.
The transformer that you were so concerned about looks OK. The orange muck is just varnish usually used seal it up and to stop the wires in the coil whining.
What looks to be the high speed diodes on the heat sink just look a bit dirty.
Just finished rebuilding 2 switch mode power supplies for my TX816s
Just the caps were faulty.
All the best
Royce
> Here are some pics:
> No PSU:
> Back together:
> Back home:
> Regards to all,
> D.
>   From: drifter7508
>   > PS.
>   > Daniel
>   > From: Daniel Baum
>   > Hi all,
>   > Highly recommended.
>   > D.
>   > > Daniel
>   > > > Daniel
2009-11-28 by Daniel Baum
Excellent. That means that the original diagnosis from chevytravelleruk was
correct and that changing the power supply was justifed.
If I could have rebuilt it myself, then it would have been better to have
done so. However, since I would have had to pay someone else to do it, it
was about the same price to get a brand new one.
How can you tell that they're stuffed, BTW? It would be useful to know.
Daniel
2009-11-28 by drifter7508
Added some pictures of my OLD PSU in the photo section as well since
there are no images of the EMAX II PSU on the internet. =)
> Here are some pics:
> No PSU:
> Back together:
> Back home:
> Regards to all,
> D.
>   From: drifter7508
>   > PS.
>   > Daniel
>   > From: Daniel Baum
>   > Hi all,
>   > Highly recommended.
>   > D.
>   > > Daniel
>   > > > Daniel
2009-11-29 by rpcfender
Electrolytic caps have a number of failure modes.
They can leak the dielectric and that either appears on the PCB or the top of the cap (which is what yours look like).
The cap can swell and distort the case, easy to spot on the top. Even the rubber bung at the bottom can pop out.
They can dry out as well which usually you can't spot.
They can sometimes develop a short although you would know from the smell and sometimes the bang.
And some other not so obvious failure modes as well.
Sometimes they exhibit these signs but still work, but it is better to replace them.
Electros can fail even if the unit is unplugged in the cupboard unused for a few years.
Don't know anything about electronics, can get help? Start by replacing the caps , electrolytic ones first.
Word of warning............
 capacitors store charge.
Electrolytic ones (as the are usually a high value) can store a lethal charge.
The electro caps in a some types of power supplies are across mains voltage. Here in Australia this is 240v and can kill you even after the power is turned off. You need to wait for it to discharge and check it with a volt meter.
Sounds like replacing the whole PS was the right thing to do.
Royce
> Thanks,
> Daniel
2009-11-29 by jammie
electrolitics dont leak any more that was the old types from the 60,70,s the new types dont use oil
the caps fail due to heat which causes oxidiation build up inside the cap which makes it harder to hold charge when it can no longer hold charge
they dont fail if not used or over time in storage it the over use and the leaving the psu on constanly not powering down the instruments which is what happens in expensive studio,s where they are left on 24/7
and the cap does not get chance to cool down
its hard to tell by looking at a cap if its heat damaged the best way is an oscilliscope which can show you the charge and discharge sequence which will show you if the cap is damaged or not
80 oc cap is only good for 3-4000 hours at 80 oc if you replace for 105 oc grade thay will work for 10-20000 at max 105oc temp
so you can see that if an instrument is kept on all the time and reaches a max temp of 80 oc then 4000 hours at this max temp wont last for very long
so switch of when not in use they last longer
i have an mirage from new and a emax from new that still work from there original psu these machines are over 20+ years old and still going strong but i only switch them on when needed so the caps never get hot enough to oxidise
  Sent: Sunday, November 29, 2009 1:14 PM
  Royce
  > Thanks,
  > Daniel
  Checked by AVG - www.avg.com
  Version: 8.5.426 / Virus Database: 270.14.86/2533 - Release Date: 11/28/09 19:34:00
2009-11-30 by rpcfender
Hi Jamie,
Point taken, but we are talking about old gear.
I have had 2 caps a SMPS in my Morpheus leak all over the board and in 4 in one of my TX816s made in the 80's the other that had been sitting in the cupboard and had barely been used also failed. No thousands of hours and no 'cooking' on these units, but they could have been not so goo from the start, but my experience with Yamaha gear has been very positive.
I was told by a company that specializes in SMPS rebuilds here in Australia that this is common. They very kindly helped me rebuild the power supplies  via email and this was the procedure they used.
DO NOT DO THIS on a powered up switch mode power supply.
My understanding is you need an isolating transformer to do this safely.
For a lot of detail of SMPS repair have a look at this link
http://www.repairfaq.org/sam/smpsfaq.htm
Repair techs and they talk about safety a lot here.
Different experience, different opinion. Thanks for the info.
I hate passing on bad info. I hope I haven't done it here.
All the best
Royce
>   From: rpcfender
>   Royce
>   > Thanks,
>   > Daniel
2009-12-01 by chevytravelleruk
Yeah!!.. a classic failed switchmode.. glad you were successful Daniel :D
> PS.
> Daniel
>   From: Daniel Baum
>   Hi all,
>   Highly recommended.
>   D.
>   > Daniel
>   > > Daniel
2009-12-05 by Daniel Baum
Hi all,
Having used my Emax II with the new PSU for a while, one thing is sure; it definitely doesn't get as hot on the outside as it used to. Also the bit that get the hottest is different (it's further to the right), which I suppose is reasonable since the new PSU is a different design and a different size.
Is getting hot a symptom of dying power supplies, or is it simply because it's not the same type as the original?
D.
