Emax
Emax Timing
Emax Timing
2010-01-08 by el macaco
I can't find the message about the emax losing it's timing, but I did a test on my Emax HD SE Rack sequenced from my MPC, I sent it fast hihats, kicm snare toms, congas, everything that I had on the trap kit factory disk and it was really solid at 160 BPM.
Then I cranked it to 300 BPM, and sent 32nd note hihat rolls to it and I heard what at first sounded like the timing screwing up, but really seemed to be just voice stealing which made the beat sound janky but what remained was still in time.
I am not sure if this is a valid test for the problem you were having, but maybe try the supermode to have each sound on it's own voice.  It might help.
Also if you have a sequence and a program where it happens clearly, if you want you can send it (standard midi file for the MPC or on the emax's sequencer, up to you) and I'll test it to see if I get the same results.  it could be a problem with the machine.
I did some sampling on my emax for the first time in a while, and running the OS off of compact flash with the internal HD dead,  it is amazing how quiet it is.  But I really miss the *ZipZip ZIP* sound of the harddrive after you selected a module.  It was really nice feedback when you hit the buttons.  I guess I'll get used to it.
Hotmail: Free, trusted and rich email service.
http://clk.atdmt.com/GBL/go/196390708/direct/01/
Re: [emax] Emax Timing
2010-01-08 by Brooks Mosher
which MPC are u using, the 60/3000 or the later versions?  also when you ran
the test, did you run hi hats, kick, snare, and toms all at once?  this is
really interesting, i guess my Emax and the other one i used to use are/were
both screwed up.
yeah when i have a free minute i'll send you a midi file for you to test
(plus an audio file showing how sloppy the timing can get)...
thanks
> was still in time.
RE: [emax] Emax Timing
I used my MPC-1000 with JJ OS.  I have a 60 Mk I, but no room for it at the moment.
Yeah, I ran all the drums all at once, it was just the BS factory disk, I would like to try it with a drum kit of my own or a chopped break, but I haven't used the emax in that way much and I don't know on what zip they reside.  I will sample some drums in soon and try again.
The midi file by itself may not replicate the scenario, since if it is voice stealing, the length of samples and release times will play into how it sounds when messed up.
> To: emax@yahoogroups.com
> From: brooksmosher@...
> Date: Fri, 8 Jan 2010 12:37:53 -0600
> Subject: Re: [emax] Emax Timing
> both screwed up.
> thanks
> > was still in time.
> http://www.silveriafamily.comYahoo! Groups Links
