Emax
Using a CF-CARD from SCSIforSamplers with the Emax
2010-04-09 by esynthesist
Hi
I was wondering if anyone from the group is using a CF-CARD drive from SCSIforSamplers with his/her Emax-I ?
I have an external CF-CARD drive here which I recently ordered and it doesn't work with the Emax-I, although compatibility with Emax SE/HD is mentioned on the website of SCSIforSamplers.
By the way: I ordered this drive specifically for my Ensoniq EPS, not for my Emax, but since it doesn't work with the EPS either, I'm trying to find out now on which samplers it would work. For now it's proven to be compatible with the Emax-II, the Emulator-III and the Emulator-IIIX.
While I can (and will) use Ted Summer's internal CF drive in my Emax-I as the primary solution, I'm still wondering why the CF-CARD drive is not working.
It formats the CF card, it even saves banks to the CF card, but it can't read these banks back. Very strange !
I always get a "Hard Disk Error" on both of my Emax samplers when loading banks from the CD CARD drive. Banks I just saved with the very same drive :) The CF cards that I'm using work fine with Ted's drive by the way.
So perhaps there may be an issue with the class or type of CF card in combination with that specific SCSIForSamplers drive.
If anyone is using the CF CARD drive succesfully with the Emax-I, I'd like to hear from you !!
Thanks in advance
///E-Synthesist
Emax II SE Development Disk?
2010-04-12 by Brandt R. Gassman
Hi everyone:
I recently acquired an Emax II Turbo rack with fully expanded memory,
and I'm interested in learning more about the Spectrum Synthesis
functionality. Unfortunately, the machine did not come with the
Spectrum Synthesis Development floppy disk specific to the Emax II
series. Does anyone have a copy of this they would be willing to share
or sell?
Thanks in advance for your help,
DBM
Re: [emax] Emax II SE Development Disk?
2010-04-12 by Rish
Someone correct me if Im wrong but the Emax 2 has the SE feature as standard OS.
 Rish
  To: emax@yahoogroups.com
  Sent: Monday, April 12, 2010 7:31 AM
  Subject: [emax] Emax II SE Development Disk?
  Hi everyone:
  or sell?
  DBM
2010-04-12 by Rish
Hey Brandt!  did see it was you.
 Rish
  Hi everyone:
  or sell?
  DBM
Re: Emax II SE Development Disk?
2010-04-12 by esynthesist
The Emax SE Development disk is available from the files section of this group. It's an EMX file.
Perhaps I will upload a full disk image (e.g. for OmniFlop) also in the near future.
///E-Synthesist
--- In emax@yahoogroups.com, "Brandt R. Gassman" <brandt@...> wrote:
> Hi everyone:
> or sell?
> DBM
2010-04-13 by ditabeardmemo
Thanks E-Synthesist!
So just to clarify: The Spectrum Synthesizer development disk that E-Mu released for the original Emax also works with the Emax II? I was under the impression that the SE waveforms for the original Emax would not translate properly to the Emax II, and therefore assumed the Emax II had its own development disk. Is this incorrect?
Thanks again for your input,
DBM
> ///E-Synthesist
> --- In emax@yahoogroups.com, "Brandt R. Gassman" <brandt@> wrote:
> > Hi everyone:
> > or sell?
> > DBM
Re: Using a CF-CARD from SCSIforSamplers with the Emax
2010-04-18 by esynthesist
One other Emax user has responded via e-mail that he has exactly the same problems as me with the CF CARD on an Emax-I...
...SCSIForSamplers has removed the "Emax SE/HD" from the CF CARD compatibility list on their website now...
Anyone else who was (un)successful with the CF CARD on the Emax-I ?
///E-Synthesist
> Hi
> Thanks in advance
> ///E-Synthesist
Re: [emax] Re: Using a CF-CARD from SCSIforSamplers with the Emax
2010-04-18 by jammie
what scsi to ide board do you have with the cfcard if its the rscsi-er then these are the new revision boards and they dont work
only the older revision boards do i told the guy from scsiforsamplers this was the case as he also sold them to ensoniq customers aswell and they did not work
the new boards dont have the 3volt drain termination like the older 1 these seem to be best for the scsi1 operation which the emax1/2 and ensoniqs use
those new boards work better in the akai,s and yamaha range of samplers
and the kurz k2000 and all later models the good thing about the new cards is there is no delay as there were on the acard cards and the older iodata cards
the acard atapi cards i got from ted if i can get them to read and write to the new atapi cf readers that i am working on then there will be a solution again and they are hot swappable they work with the new iodata cards so i can fit them into akais and yams and kurz and rolands they also work with the acard7720 which do work with the emax1/2
  Sent: Sunday, April 18, 2010 3:36 PM
  Subject: [emax] Re: Using a CF-CARD from SCSIforSamplers with the Emax
  ///E-Synthesist
  > Hi
  > Thanks in advance
  > ///E-Synthesist
  Checked by AVG - www.avg.com
  Version: 8.5.437 / Virus Database: 271.1.1/2817 - Release Date: 04/17/10 18:31:00
The IDE/SCSI board in my CF CARD is currently the R-IDSC-E/R revision 1.28; first it was equipped with the version 1.30.9 but that one didn't work with any of the old Emu (up to IIIX) and Ensoniq (all) samplers. So then I received the "good" board - and indeed it's a better one but still the Emax-I and Ensoniq EPS Classic are not supported.
As far as I understand my CF CARD unit has now the "native" IDE/SCSI board which has always been in the CF CARD in the past, or am I wrong ?
Are you talking about an even older board ?
I also have the Acard AEC7720U board but its 40 pin IDE female connector doesn't accept all 40 male pins of the CF card board in the unit; one hole is factory-closed on the 7720. Could I just remove the corresponding pin from the CF card board or is this pin important for use with non-Acard boards ?
///E-Synthesist
>   ----- Original Message -----
>   From: esynthesist
>   ///E-Synthesist
>   --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
>   > Hi
>   > Thanks in advance
>   > ///E-Synthesist
Update: after an e-mail of another Emax user, I checked the current internals of my CF CARD.
It seems that the "good" board which I received a few weeks ago - and which is still not working with my Emax - is in fact NOT an R-IDSC-E/R v1.28.
After removing the SCSIForSamplers labels on it, I discovered it's an even older IDSC21-E board from 1999.
Also, the Acard AEC7720U board seems to have been tested with the CF Card board from the CF CARD before by another Emax user. And also with that adapter board, the Emax-I is not supported. It results in the same error ("Hard Disk Error").
And as I mentioned before, the 2006 R-IDSC-E/R v1.30.9 is not working either, and someone else tried a 2009 board which also doesn't work.
So I am really wondering now which CF CARD version has ever supported the Emax-I ?
Or would the problem be caused by a change of the CF Card board in the drive, and not only by the IDE/SCSI adapter board ?
///E-Synthesist
> ///E-Synthesist
> >   From: esynthesist
> >   ///E-Synthesist
> >   > Hi
> >   > Thanks in advance
> >   > ///E-Synthesist
2010-04-19 by Ted Summers
1) The pin 29 is a master / slave designation pin on tne IDE Interface
when using CABLE SELECT for IDE bus. If you have jumpered master you
shouldn't need this pin.
It isn't required to be there.
or you should get a different IDE cable that matches the connection.
2) The Acard 7220U bridge board I have used with an IDE CF drive and
also a Zip drive in my Emax rack without issue.
One thing of note- there is a firmware update for the Acard bridge
board.
Previous versions of the firmware can result in Hard Disk Error
messages.
Make sure your bridge has the latest firmware.
To update it, you put it in a PC with a drive attached and run the
updater.
The updater is in windows.
Ted
v1.28.
the Emax-I ?
///E-Synthesist
supported.
wrong ?
 > ///E-Synthesist
samplers
 > > From: esynthesist
Emax
 > > ///E-Synthesist
 > > > Hi
the Emulator-IIIX.
drive by the way.
 > > > Thanks in advance
 > > > ///E-Synthesist
04/17/10 18:31:00
2010-04-19 by jammie
no its an older version 1 board from iodata that works with the emax 1/2 and ensoniqs its called an idesc12-e and it was upto revision 2 software which was the latest os fore it it has 3 extra pins for different types of termination these are the only 1,s that work with ensoniqs
as for a missing pin on your aec7720u mine has the standard 40 pin female plug with all pins showing
  Sent: Sunday, April 18, 2010 9:34 PM
  ///E-Synthesist
  > From: esynthesist
  > ///E-Synthesist
  > > Hi
  > > Thanks in advance
  > > ///E-Synthesist
  Version: 8.5.437 / Virus Database: 271.1.1/2818 - Release Date: 04/18/10 06:31:00
2010-04-20 by esynthesist
Do you mean the IDSC21-E or an IDSC12-E ?
In fact I have the IDSC21-E from 1999. But where are the additional 3 pins ? As far as I remember it has the same jumperlayout as the R-IDSC-E/R.
>   From: esynthesist
>   ///E-Synthesist
>   > From: esynthesist
>   > ///E-Synthesist
>   > --- In emax@...m, "esynthesist" <esynthesist@> wrote:
>   > > Hi
>   > > Thanks in advance
>   > > ///E-Synthesist
2010-04-21 by jammie
the additional 3 pins are at the bottom right seprate from the other jumper pins i was the 1 who gave the pin configuraton to scsiforsamplers to make them work with ensoniqs as i was using that card for 8 years before he started to sell them
  Sent: Tuesday, April 20, 2010 10:04 PM
  > From: esynthesist
  > ///E-Synthesist
  > > From: esynthesist
  > > ///E-Synthesist
  > > > Hi
  > > > Thanks in advance
  > > > ///E-Synthesist
  Version: 8.5.437 / Virus Database: 271.1.1/2823 - Release Date: 04/20/10 12:45:00
Re: [emax] Re: Emax II SE Development Disk?
2010-04-22 by Simon Forsyth
Emax I banks can be covert loaded into th Emax II without issue and then saved back out as a 16 bit bank.
There was a SE synthesis banks set in Emax II library, but I can't remember if it had the single cycle waveforms the Emax I disc had. either way, I have both and can supply them in EMX format
Simon
Sent: Tue, April 13, 2010 1:36:01 AM
Subject: [emax] Re: Emax II SE Development Disk?
DBM
> ///E-Synthesist
> --- In emax@yahoogroups. com, "Brandt R. Gassman" <brandt@> wrote:
> > Hi everyone:
> > or sell?
> > DBM
2010-04-22 by esynthesist
You're right, this board has 3 additional jumpers (CN5, pins A, B, C) which are missing on the R-IDSC-E/R.
Any idea how the jumpers should be set for Ensoniq EPS Classic and Emax-I ? It was delivered with jumpers B and C set (3-state internal SCSI termination). Should it be only A set (open drain) ? Could something be damages when changing these jumpers ?
>   From: esynthesist
>   > From: esynthesist
>   > ///E-Synthesist
>   > > From: esynthesist
>   > > ///E-Synthesist
>   > > > Hi
>   > > > Thanks in advance
>   > > > ///E-Synthesist
2010-04-23 by esynthesist
I just tried other jumper settings on those 3 additional pins but there's no difference at all: this CF CARD unit still doesn't work with neither my Emax I nor my Ensoniq EPS Classic.
I'm wondering whether the problem is not caused by the jumpers on the CF Card board instead of the adapter board...
> >   From: esynthesist
> >   > From: esynthesist
> >   > ///E-Synthesist
> >   > > From: esynthesist
> >   > > ///E-Synthesist
> >   > > > Hi
> >   > > > Thanks in advance
> >   > > > ///E-Synthesist
