> Very informative! Thanks to both e-synthesist and Rob for your troubleshooting advice.
> Unfortunately for me, I do not own a SCSI CD-Rom unit that I can connect to my Emax II. I use EMXP and CF cards for all my bank storage. As such, I cannot load the bank directly to the Emax and remove the corrupted sequencer tracks.
> Is there someone who can send me a "clean" version of this bank as a .EB2 file? Or even a floppy disk image with the corrupted version that I can edit myself?
> Thanks again to everyone for your help.
> Best,
> DBM
> --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
> > Indeed, it's a problem with the sequences and removing them will solve the problem - that doesn't hurt since there are no sequences programmed in that bank.
> > FYI: the errorcodes are shortly explained in the EMXP manual (page 44 in latest version). Bank error 3 means problem with sequence addresses.
> > I just tested this bank in my Emax-II and the bank is indeed corrupt. If you try to select sequence S09 and press PLAY, the Emax-II will crash. It's the S09 address which is corrupt in the bank data.
> > When designing EMXP I knew that EMXP was going to be very strict/intolerant in its validations whether to accept or not accept banks and files.
> > The question is to what extent EMXP should "allow" corrupt banks.
> > EMXP contains a set of validation routines which look for some patterns in Emax files and banks to make sure it's really an Emax compliant file or bank. EMXP has to do it like this, because Emax files/banks don't carry a "universal" identifier/stamp proving it is an original Emax file/bank.
> > The sequence address logic test is one of those EMXP validation routines :)
> > ///E-Synthesist
> > --- In emax@yahoogroups.com, Robert Cary <rob_kari@> wrote:
> > > Hi
> > > I had the same problem with this bank. It's a error with the sequences. If you go into sequencer setup and erase the tracks you'll be able to convert it without any problems.
> > > Rob
> > > --- On Sat, 17/4/10, ditabeardmemo <brandt@> wrote:
> > > > From: ditabeardmemo <brandt@>
> > > > Subject: [emax] Prob
> > > > To: emax@yahoogroups.com
> > > > Date: Saturday, 17 April, 2010, 21:07
> > > > Hi everyone:
> > > > I recently purchased a new copy of the Greytsounds Emax II
> > > > library CDR, and converted all the banks to .EB2 image files
> > > > (using EMXP, of course) so that I could transfer them to
> > > > CompactFlash cards.
> > > > When EMXP listed the contents of the CD-R, however, it
> > > > identified Bank 97 ("Orchestral Brass") as corrupt. I could
> > > > neither copy nor convert this bank, nor see its contents.
> > > > Does anyone know why this might be, and if there is a
> > > > workaround? More importantly, does anyone have a copy of
> > > > this bank for the Emax II that is working?
> > > > Thanks in advance for your help!
> > > > DBM
> > > > Emax and Emax II User's Group Website
> > > > http://www.silveriafamily.comYahoo! Groups Links
> > > > emax-fullfeatured@yahoogroups.com
