Emax 1 Rack HD - Dirty Noise when sampling
2010-11-03 by Twelve bits addicted
Hi everybody, Since a few days, when sampling with my Emax 1 Rack HD, I get a "dirty noise", something that looks like an old time code signal, a clock signal, or something like that... I tried differents sampling frequencies, and it's still here, but at a different freqency... I also tried to unplug the HD : same results. Any idea of what I can do ? Is my best sampler dead ? Thanks for your help !
2010-11-03 by roy thomas
ITS THE TYPE OF CABLE YOUR USEING TO PLUG UP TO THE EMAX TRY MONSTAR CABLE'S ________________________________
To: emax@yahoogroups.com
Sent: Wed, November 3, 2010 5:33:15 AM
Subject: [emax] Emax 1 Rack HD - Dirty Noise when sampling
Hi everybody,
like that...
freqency...
[Non-text portions of this message have been removed]2010-11-03 by James Ulibarri
or Mogami (even better). On Wed, Nov 3, 2010 at 2:27 PM, roy thomas <melechdidymus20012001@...>wrote: > > > ITS THE TYPE OF CABLE YOUR USEING TO PLUG UP TO THE EMAX TRY MONSTAR > CABLE'S > > ________________________________ > From: Twelve bits addicted <twelvebitsaddict@...<twelvebitsaddict%40yahoo.com> > > > To: emax@yahoogroups.com <emax%40yahoogroups.com> > Sent: Wed, November 3, 2010 5:33:15 AM > Subject: [emax] Emax 1 Rack HD - Dirty Noise when sampling > > > > Hi everybody, > > Since a few days, when sampling with my Emax 1 Rack HD, I get a "dirty > noise", > something that looks like an old time code signal, a clock signal, or > something > like that... > > I tried differents sampling frequencies, and it's still here, but at a > different > freqency... > > I also tried to unplug the HD : same results. Any idea of what I can do ? > > Is my best sampler dead ? > > Thanks for your help ! > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
2010-11-03 by Elk Latham
or canare ________________________________
From: James Ulibarri <jamesulibarri@...> To: emax@yahoogroups.com Sent: Wed, November 3, 2010 2:48:04 PM Subject: Re: [emax] Emax 1 Rack HD - Dirty Noise when sampling or Mogami (even better). On Wed, Nov 3, 2010 at 2:27 PM, roy thomas <melechdidymus20012001@...>wrote: > > > ITS THE TYPE OF CABLE YOUR USEING TO PLUG UP TO THE EMAX TRY MONSTAR > CABLE'S > > ________________________________ > From: Twelve bits addicted ><twelvebitsaddict@...<twelvebitsaddict%40yahoo.com> > > > To: emax@yahoogroups.com <emax%40yahoogroups.com> > Sent: Wed, November 3, 2010 5:33:15 AM > Subject: [emax] Emax 1 Rack HD - Dirty Noise when sampling > > > > Hi everybody, > > Since a few days, when sampling with my Emax 1 Rack HD, I get a "dirty > noise", > something that looks like an old time code signal, a clock signal, or > something > like that... > > I tried differents sampling frequencies, and it's still here, but at a > different > freqency... > > I also tried to unplug the HD : same results. Any idea of what I can do ? > > Is my best sampler dead ? > > Thanks for your help ! > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed] ------------------------------------ Emax and Emax II User's Group Website http://www.silveriafamily.comYahoo! Groups Links [Non-text portions of this message have been removed]
2010-11-03 by jujulilianan@...
Sounds like time for a service to me... electronic fault suggested by the nature of the interference changing when you change sample rates.... could be pre a to d, which would be relatively simple but depending on the type of noise you're getting it may be a purely digital problem... If you don't have signal tracing experience you're best off taking it to someone who does. Ps don't buy monster products.... Mogami, canare, klotz are all great cable material. Buy from a cable maker who uses these cable brands. Or use them yourself to make your own cables.
--- Original Message ---
Sent: 4 November 2010 4/11/10
From: Twelve bits addicted <twelvebitsaddict@yahoo.com>
Hi everybody,
like that...
freqency...
http://www.silveriafamily.comYahoo! Groups Links2010-11-04 by Twelve bits addicted
Hi, I'm getting this noise even if nothing is connected to the sampler input... It's not very loud, but I do hear it, that is enough for my ears. Especially when I pitch down a sample :( And I'm not electronician, so someone else has to take my emax back to life. I'm going to try with professional electronicians around me. Thanks for your answers. I'll post if I find some informations. --- In emax@yahoogroups.com, "jujulilianan@..." <jujulilianan@...> wrote:
> > Sounds like time for a service to me... electronic fault suggested by the nature of the interference changing when you change sample rates.... > > could be pre a to d, which would be relatively simple but depending on the type of noise you're getting it may be a purely digital problem... If you don't have signal tracing experience you're best off taking it to someone who does. > > Ps don't buy monster products.... Mogami, canare, klotz are all great cable material. Buy from a cable maker who uses these cable brands. Or use them yourself to make your own cables. > > --- Original Message --- > > From: roy thomas <melechdidymus20012001@...> > Sent: 4 November 2010 4/11/10 > To: emax@yahoogroups.com > Subject: Re: [emax] Emax 1 Rack HD - Dirty Noise when sampling > > ITS THE TYPE OF CABLE YOUR USEING TO PLUG UP TO THE EMAX TRY MONSTAR CABLE'S > > > > > ________________________________ > From: Twelve bits addicted <twelvebitsaddict@...> > To: emax@yahoogroups.com > Sent: Wed, November 3, 2010 5:33:15 AM > Subject: [emax] Emax 1 Rack HD - Dirty Noise when sampling > > Â > Hi everybody, > > Since a few days, when sampling with my Emax 1 Rack HD, I get a "dirty noise", > something that looks like an old time code signal, a clock signal, or something > like that... > > > I tried differents sampling frequencies, and it's still here, but at a different > freqency... > > > I also tried to unplug the HD : same results. Any idea of what I can do ? > > Is my best sampler dead ? > > Thanks for your help ! > > > > > > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links >
2010-11-04 by jammie
buy your own cable and make your own most cable manufacturers use vandamm cable which is the best audio cable brand i buy mine on a 100 meter drum at £80 and cables dont usually cause noise if they do then its earth loop hum and the only way to get rid of that is di boxes with isolation transformers and earth lift or by having a seperate earth electrode rod and a clean earth to all your sockets in the studio isolating the incomming supply where most earth loop noise comes from now it sounds like you need a service it could be a couple of things but the most likely its the dac for the audio to the filter ic,s if it were just 1 filter ic then when you press all eight keys you would only get a few voices playing but if you are getting none then the audio feed to the filters is at fault i diagnosed a similar problem to another members emax the cv dac was faulty and when controller info was sent it would not change the the filter cutoof or the volume or the panning or it could be the sample and hold circuit which are 4051 octal sample and holds you can change these for smp08 from analog devices they have a better slew rate and are analog devices pin for pin upgrade now to check these properly you will need a oscillascope and a logic anyliser to see if they are working correctly if you have not got 1 of these then you can try the chip replacement method desolder the component and fit a ic socket than in future servicing if a part goes you can just unplug and fit a new 1 i can tell you what ic to remove and try ill sift through the schematics for you
Sent: Wednesday, November 03, 2010 10:45 PM
Hi everybody,
like that...
freqency...
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3235 - Release Date: 11/03/10 08:36:00
