Emax
Using the Plus OS on an EMAX HD SE
2010-11-18 by tcb80234
I purchased a second EMAX on eBay. The Hard Drive was toast.   I have a new hard drive (exact match) and a zip Drive.  The Plus OS will not work on the hard drive or the zip. The SEHD11 OS works perfectly on both.   Do I have to upgrade the chips on the CPU (it's a 333)to use the Plus OS?
thx, Tom
Re: Using the Plus OS on an EMAX HD SE
One more thing- It is a Factory EMAX SE HD, no modifications or upgrades
Tom
> thx, Tom
Re: [emax] Re: Using the Plus OS on an EMAX HD SE
2010-11-18 by jammie
dont need the scsi upgrade kit it already has it installed all you need is a zip drive that can bee set to scsi id 0 which means you need an internal zip drive in a external case for it to be changed to this id as for the replacement drive have you set it to scsi id 0
otherwise it will always run os from floppy
the only difference with the plus os is that you can set what scsi drive you want to scan and load instruments from once os is loaded you can set it to another id its set in software in the rom as scsi id0
  To: emax@yahoogroups.com
  Sent: Thursday, November 18, 2010 12:43 AM
  Subject: [emax] Re: Using the Plus OS on an EMAX HD SE
  Tom
  > thx, Tom
  Checked by AVG - www.avg.com
  Version: 8.5.449 / Virus Database: 271.1.1/3262 - Release Date: 11/17/10 07:34:00
