Emax II backlight inverter
2010-11-17 by Louis van Dompselaar
Does anyone here happen to know what voltage the inverter for the Emax II backlight runs on? I want to replace mine with one of the silent SMD ones from backlights4u but the smaller one can't run on 5V and the Emax II one might just run on 5V. If no one knows I'll get the board out and find out, but would safe time if someone does. Louis
2010-11-17 by jammie
5v only on the emax but you can fit a 3v version but you need to add a pot or resister to bring it down to 3v
To: emax@yahoogroups.com
Sent: Wednesday, November 17, 2010 9:21 AM
Subject: [emax] Emax II backlight inverter
Louis
Checked by AVG - www.avg.com
Version: 8.5.449 / Virus Database: 271.1.1/3261 - Release Date: 11/16/10 19:34:00
[Non-text portions of this message have been removed]2010-11-17 by Louis van Dompselaar
Thanks Jammie It has a new backlight and new sliders so it was annoying that the new backlight actually made the whining worse, so much so that I actually can't have it on without getting a headache... (and I'm not mentioning what it does to the cats...) Op 17 nov 2010, om 14:33 heeft jammie het volgende geschreven: > 5v only on the emax but you can fit a 3v version but you need to add a pot or resister to bring it down to 3v > > [Non-text portions of this message have been removed]
Although having written what I did below, I must admit that my last attempt yesterday has worked better than expected. I pumped the transformer in the inverter full of plastic spray (the one you use to coat PCB's with) yesterday. This has now hardened and has almost completely silenced it. Oh well, trust me to check that AFTER ordering the new inverters... Op 17 nov 2010, om 19:05 heeft Louis van Dompselaar het volgende geschreven: > Thanks Jammie > > It has a new backlight and new sliders so it was annoying that the new backlight actually made the whining worse, > so much so that I actually can't have it on without getting a headache... (and I'm not mentioning what it does to the cats...) > > [Non-text portions of this message have been removed]
2010-11-17 by Ted Summers
are you sure it is the backlight and not the Inverter block on the main logic going bad? That is a part easy to replace that can also cause noise as it vibrates due to the transformer.... just a thought Ted On Wed, Nov 17, 2010 at 10:05 AM, Louis van Dompselaar <louis@... > wrote: > > > Thanks Jammie > > It has a new backlight and new sliders so it was annoying that the new > backlight actually made the whining worse, > so much so that I actually can't have it on without getting a headache... > (and I'm not mentioning what it does to the cats...) > > Op 17 nov 2010, om 14:33 heeft jammie het volgende geschreven: > > > 5v only on the emax but you can fit a 3v version but you need to add a > pot or resister to bring it down to 3v > > > > > > [Non-text portions of this message have been removed] > > > [Non-text portions of this message have been removed]
It *is* the inverter that is causing the noise. That's why I'm looking to replace it... Op 17 nov 2010, om 19:51 heeft Ted Summers het volgende geschreven:
> are you sure it is the backlight and not the Inverter block on the main > logic going bad? > That is a part easy to replace that can also cause noise as it vibrates due > to the transformer.... > > just a thought > > Ted
2010-11-17 by dutchbeats
can someone share the name of a matching inverter for the PC1602AR-H <http://gx.rs-online.com/web/search/searchBrowseAction.html?method=searc\ hProducts&searchTerm=PC1602AR-H&x=0&y=0> for emax i keyboard? --- In emax@yahoogroups.com, Louis van Dompselaar <louis@...> wrote: > > It *is* the inverter that is causing the noise. > That's why I'm looking to replace it... > > Op 17 nov 2010, om 19:51 heeft Ted Summers het volgende geschreven: > > > are you sure it is the backlight and not the Inverter block on the main > > logic going bad? > > That is a part easy to replace that can also cause noise as it vibrates due > > to the transformer.... > > > > just a thought > > > > Ted > [Non-text portions of this message have been removed]
digi-key or mouser.com..... that is where I got mine.... On Wed, Nov 17, 2010 at 10:59 AM, Louis van Dompselaar <louis@... > wrote: > > > It *is* the inverter that is causing the noise. > That's why I'm looking to replace it... > > Op 17 nov 2010, om 19:51 heeft Ted Summers het volgende geschreven: > > > > are you sure it is the backlight and not the Inverter block on the main > > logic going bad? > > That is a part easy to replace that can also cause noise as it vibrates > due > > to the transformer.... > > > > just a thought > > > > Ted > > > [Non-text portions of this message have been removed]
2010-11-18 by jammie
the inverter only changes the voltage for the contrast of the lcd remember from + to negative which was how the old lcd worked the efoil converter is a power switching transistor and a step up transformer so that it can take a 5v signal and change it into a 5v ac signal which is then aplified by the step up transformer for the correct required voltage for thwe efoil to produce light this is on the main board its a green square this is the item that produces a whine when you loose the backlight they also can get dammaged from a backlight fading for to long the produce a high pitched humb
Sent: Wednesday, November 17, 2010 6:59 PM
Subject: Re: [emax] Emax II backlight inverter
> logic going bad?
> just a thought
> Ted
Version: 8.5.449 / Virus Database: 271.1.1/3262 - Release Date: 11/17/10 07:34:00
[Non-text portions of this message have been removed]2010-11-18 by jammie
they dont use an inverter as it use +4.7 max voltage and need to have a pot from +5v source and ground and ythe wiper goes to pin 3
Sent: Wednesday, November 17, 2010 8:29 PM
Subject: [emax] Re: Emax II backlight inverter
main
> > logic going bad?
vibrates due
> > just a thought
> > Ted
