Emax
Got another Emax.... working screen this time
2011-04-20 by mlivingston8
So it must be an Atlanta thing but I got another Emax I for around $150.  But this time it's the SE version with revision 2b digital board (the first one was an HD with rev. 3.3 scsi installed.)  It needed a floppy drive so I swapped in the one from the first Emax so that's sorted.  But it seems that the HD OS disk I have will not run the SE Emax.  Anyone have the SE OS available?  I'd love to finally have a working Emax!  This one is *MINT* with original box, packaging materials and manual.  Unbelievable!  Just need that SE OS disk..
Re: Got another Emax.... working screen this time
2011-04-21 by hifiassassin
Congratulation on that, nice price.
Anyone on the board is invited to correct me, but I believe you can remove the SE upgrade on the newly purchases Emax, and install it into the HD version you had, giving you an SE HD, or a Plus.
If the board in the HD has the upgrade socket, it should be fine.  After that, you will need to install the SE software upgrade.  That may or may not be a challenge.  I know the files for that are available online, although I've never tested them myself (I have 1 SE, and one SE HD.  Both racks).
Here is a link to the emulator archives' OS list, so you'll know what OS you need:
	http://emulatorarchive.com/Samplers/EmaxOverview/EmaxOS/emaxos.html
And here is a link to my server with all of the OS versions, including the SE upgrade.  But as I said, I have not tested the SE upgrade myself.
	http://hifidesign.net/POST/FILES/EMAX_FILES.zip
I purchased the 2 Emax racks, as well as a separate digital board, just to put together a single working Emax SE HD.  The second Emax was supposed to be a SE HD with a bad power supply, purchased from ebay.  It wasn't.  It was only an SE, and it wasn't the power supply that was bad either.  The seller was nice, though, and he refunded my money, minus shipping, and let me keep the rack.  So I know how you feel, swapping parts and all.
Good luck.
John...
2011-04-24 by mlivingston8
Thanks for the reply and files.  I've put them in my "emax resource folder" on my computer.  I'm giving the Emax HD to a friend in another state because he has the time and patience to fix her up.  I'd love to keep it for parts but if anyone can fix it, he can.  Mine is working and is in better physical shape anyway.  I'll probably get another one for parts down the road.  The emax seems to be the only thing with the SSM2047 so gonna need a donor unit eventually.
Here are my problems right now with mine:
I need the SE OS on a DS/DD floppy.  I have no way to write the OS since that format is outdated.  I tried to contact route66 studios about buying the disk but no response.  Can anyone help?
I don't have any sound disks.  I have the complete Emax II library though.  I assume that I just need to convert these with EMXP and then send them to the Emax with the (after building) the EMuSer.   Correct?  Once I send the banks with that program, can I then write them to floppy disk with the Emax?  Is this thinking correct?
> Good luck.
> John...
Re: [emax] Got another Emax.... working screen this time
2011-04-24 by James Ulibarri
Try Ebay.
On Wed, Apr 20, 2011 at 11:10 AM, mlivingston8 <mlivingston8@gmail.com>wrote:
> SE OS disk..
Re: [emax] Re: Got another Emax.... working screen this time
2011-04-24 by jammie.emma@...
you can only do 1mb banks with the emax1 from emax2 library
you dont need a emuser you can just write the files to floppy disk with emxp
the os is in emxp and if not ask esynthesis
very rare that a voice chip goes its usually the cv dac or a 4051 sample and hold and caps
  To: emax@yahoogroups.com
  Sent: Sunday, April 24, 2011 4:23 AM
  Subject: [emax] Re: Got another Emax.... working screen this time
  > Good luck.
  > John...
  Checked by AVG - www.avg.com
  Version: 9.0.894 / Virus Database: 271.1.1/3592 - Release Date: 04/23/11 07:36:00
2011-04-26 by mlivingston8
Cool, good to know.  The problem I face is formatting the required floppy disks.  How are peeps using the floppy drive doing this?  With an old computer?  I have a dell with a floppy drive but I'm pretty sure it's only for HD disks, not DS/DD, right?  Is there a trick, like covering a hole on HD disks or something?  Any advice would be stellar.
>   ----- Original Message -----
>   From: mlivingston8
>   > Good luck.
>   > John...
2011-04-26 by jammie.emma@...
get omniflop it will give you a system to control the onboard floppy controller
all hd drives are ds/dd compatible
in dd disks there is no hole so when you put it into a hd drive the pin will not drop and so it will know its a dd disk and will do the magnetic writing pulse required for a dd disk
in a hd disk there is a hole which tells the floppy that when the disk is inserted the pin will fall in the hole so the disk drive will go into hd mode and produce the require magnetic pulse for that tape medium
i use hd drives in my samplers that require dd drives but have to use dd disks so that it will format to 720k or 800k depending on what system it formats at
the tape is different between disks and that is why they use different strengths of magnetic pulse
  Sent: Tuesday, April 26, 2011 3:54 AM
  > From: mlivingston8
  > > Good luck.
  > > John...
  Version: 9.0.894 / Virus Database: 271.1.1/3597 - Release Date: 04/25/11 19:34:00
Wow, great info!  This is starting to make so much more sense to me now.  So the Emax will accept nearly any HD disk drive as areplacement when my stock drive fails?  Or are specific requirements needed when choosing a replacement drive?
Anyway, I ordered some new old stock DD/DS disks so hopefully I can get this one going by next week!  Thanks for the knowledge dropped!
>   From: mlivingston8
>   > From: mlivingston8
>   > > Good luck.
>   > > John...
2011-04-27 by jammie.emma@...
you need a drive that can jumper ds0
or use a slim floppy converter board and use a hd slim floppy works great thanks to ted and cost only £5 plus postage of of ebay
  Sent: Tuesday, April 26, 2011 11:15 PM
  > From: mlivingston8
  > > From: mlivingston8
  > > > Good luck.
  > > > John...
  Version: 9.0.894 / Virus Database: 271.1.1/3599 - Release Date: 04/26/11 19:34:00
2011-04-29 by mlivingston8
Finally!  Made SOME progress.  Installed the omniflop drivers on my old dell and was able to format and load the OS to a DD/DS floppy using EMXP.  I am able to boot the Emax now, awesome!!!
I need help figuring out how to get the sound banks for the Emax II through EMPX and to my Emax I.  I read the below posting about the Emax I only able to handle 1mb banks from the II library.  What's the best strategy for getting floppies full of banks/sounds for my Emax?  Sorry, I'm learning all this stuff new.  I'm trying to read but could use a little guidance with this one.
>   From: mlivingston8
>   > From: mlivingston8
>   > > From: mlivingston8
>   > > > Good luck.
>   > > > John...
2011-04-29 by jammie.emma@...
only 1mb files as some of the banks for the emax2 are way to big ask esynthesis but its all in his pdf explaining how to do it
  Sent: Friday, April 29, 2011 8:37 AM
  > From: mlivingston8
  > > From: mlivingston8
  > > > From: mlivingston8
  > > > > Good luck.
  > > > > John...
  Version: 9.0.894 / Virus Database: 271.1.1/3604 - Release Date: 04/29/11 07:34:00
2011-04-30 by mlivingston8
Yeah, I need to study the manual some more but between the Octatrack, DP/4 and the Emax, I've been in RTFM hell.
Anyway, I directly sampled in the saw from my Juno 106 and got some nice stuff going on the Emax.  Those SSM2047 VCF/VCA are great.  But THAT arppegiator!!!!  Man, I didn't even expect it to be that cool.  This board is going to fit great in my music once I figure everything out with it.  Such a great sounding sampler/synth, I love it already!
>   From: mlivingston8
>   > From: mlivingston8
>   > > From: mlivingston8
>   > > > From: mlivingston8
>   > > > > Good luck.
>   > > > > John...
