Well, I have tried an NEC, Sony, and TEAC successfully- someone else tried a
Mitsumi.
I don't think compatibility is much of an issue.
I used TEAC FD-05x (several models, some end in G, some H, etc).
Just make the slim floppy converter as I have it on my page:
http://djtbs1.wordpress.com/2011/08/09/jm215a-slim-floppy-adapter-modifications/
On Tue, Sep 27, 2011 at 12:23 PM, Johnny Tomasello <johnny@...>wrote:
> I found some slim floppy drives online, but am not sure if they're
> compatible with the Emax I. I looked through the group and didn't find any
> specs.
> Is there something I should be looking for in the drive to ensure
> compatibility?
> On Sep 27, 2011, at 2:17 PM, <jammie.emma@...> <
> jammie.emma@...> wrote:
> > Ł5 on ebay
> > From: timbreadvantage
> > To: emax@yahoogroups.com
> > Sent: Tuesday, September 27, 2011 6:49 PM
> > Subject: [emax] Re: Emax SCSI issues
> > Sounds great- Have any for sale?
> > --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> > > This is exactly why every one of my units has a slim floppy in it.....
> > > On Mon, Sep 26, 2011 at 7:04 AM, timbreadvantage
> > > <timbreadvantage@...>wrote:
> > > > I have been having a similar issue with my Emax SE HD rack,
> > > > My floppy drive has failed- I have the old Miniscribe drive (works
> but is
> > > > soooooo loud). Have the SCSI to IDE ACard and an IDE CF reader.
> > > > If someone could post an EXMP CF image with the "+" OS, I might be
> able to
> > > > get up and running again (sans noisy HD).
> > > > I believe this would help the original poster- and future Emax users
> as
> > > > well.
> > > > --- In emax@yahoogroups.com, w.niessen@ wrote:
> > > > > And be sure that you put the Cable on the Mainboard is in Center of
> > > > > the connector.
> > > > > If you ever disconnected the Cable. Check it!
> > > > > On time I made this mistake and placed the Plug one pin to the
> right
> > > > > and got the same error as you.
> > > > > Check also that the red line is on Pin one.
> > > > > Am 14.09.2011 um 13:13 schrieb <jammie.emma@>:
> > > > > > issue with internal cable check that none of the strands has
> broken
> > > > > > loose
> > > > > > common fault caused by people pulling on the cable rather than
> > > > > > useing a
> > > > > > proper tool
> > > > > > just take off old idc connectors and reseat with a idc crimp tool
> > > > > > this will
> > > > > > make new connection to the ribbon cable as they cut in the cable
> > > > > > making a
> > > > > > connection
> > > > > > or if you have a spare scsi cable try that
> > > > > > also is your drive got the updated firmware as some would only
> read
> > > > > > and not
> > > > > > write which could also be the problem
> > > > > > From: "Scott Stanley" <scartattack@>
> > > > > > To: <emax@yahoogroups.com>
> > > > > > Sent: Wednesday, September 14, 2011 2:02 AM
> > > > > > Subject: Re: [emax] Re: Emax SCSI issues
> > > > > >> The only drives connected are the
> > > > > >> Slim floppy drive and the pcd-50b. The internal hard drive
> ceased to
> > > > > >> function.
> > > > > >> I tested this same floppy drive, PCD-50b, PCMCIA adapter, CF
> card
> > > > > >> and scsi
> > > > > >> cable in my Emax II and it worked fine. Issue with my internal
> SCSI
> > > > > >> perhaps? :(
> > > > > >> -Scott
> > > > > >> On 2011-09-13, at 8:39 PM, Ted Summers <djtbs1@> wrote:
> > > > > >> Yes, all jumpers removed is ID 0 on the PCD-50b
> > > > > >> Emax 1's only boot from ID0, and that is what the HD is set to
> by
> > > > > >> default
> > > > > >> from the factory.
> > > > > >> If the internal HD is connected and the PCD-50b also, and both
> at
> > > > > >> ID0, it
> > > > > >> isn't going to work right.
> > > > > >> On Sep 13, 2011, at 4:52 PM, Scott Stanley wrote:
> > > > > >> The only jumper I have set is on termination. All other jumpers
> > > > > >> have been
> > > > > >> removed so, it should already be set to scsi id 0, correct?
> > > > > >> -Scott
> > > > > >> On 2011-09-13, at 7:19 PM, "jammie.emma@" <
> > > > > >> jammie.emma@> wrote:
> > > > > >> 0 you need to set the card drive to 0 or otherwise you will need
> > > > > >> the + os
> > > > > >> to
> > > > > >> see the card drive if it is not set to scsi id 0
> > > > > >> Sent: Tuesday, September 13, 2011 11:44 PM
> > > > > >>> When the SCSI is backwards, the floppy will not load the OS. I
> > > > > >>> have not
> > > > > >>> tried using EMXP yet but, that OS a good idea. Thanks for the
> > > > > >>> suggestion.
> > > > > >>> Question... Does anyone know if the internal Emax HD was hard
> set
> > > > > >>> to a
> > > > > >>> specific SCSI ID?
> > > > > >>> -Scott
> > > > > >>> On 2011-09-13, at 5:19 PM, "kconnor9000" <kevinconnor@>
> > > > > >>> wrote:
> > > > > >>> Dumb point to mention perhaps, but it's possible to plug in
> > > > > >>> internal SCSI
> > > > > >>> connector in backwards fashion, no? I hope it's something
> simple
> > > > > >>> like
> > > > > >>> that,
> > > > > >>> for you. Power is usually what I f** up first, but you mention
> the
> > > > > >>> LED,
> > > > > >>> so
> > > > > >>> you're miles ahead already!
> > > > > >>> Maybe someone with a proven CF card formatted with an emax HD
> os
> > > > > >>> image
> > > > > >>> could
> > > > > >>> send you one in the mail? Figure out if it's only a
> write-access
> > > > > >>> issue.
> > > > > >>> You
> > > > > >>> could try making one with emxp and a cheap usb-card writer,
> perhaps.
> > > > > >>> Best luck, KevinC
> > > > > >>> --- In emax@yahoogroups.com, Scott Stanley <scartattack@>
> wrote:
> > > > > >>>> I am installing a slim floppy drive and PCD-50b into an Emax
> HD
> > > > > >>>> (non
> > > > > >>>> SE) rack, model #1021, serial # 028541, CPU PCB PC 333 Rev A.
> > > > > >>>> The Emax HD can see the slim floppy drive, also load and save
> > > > > >>>> without
> > > > > >>> issues.
> > > > > >>>> The Emax HD appears to see PCD-50b (the proper LED turns on
> when
> > > > > >>>> requested) however, it will not complete a format of the
> PCMCIA CF
> > > > > >>>> card. After about 5 minutes or so (depending on what size of
> CF
> > > > > >>>> card
> > > > > >>>> that I use) it displays a message saying "scsi hardware
> error".
> > > > > >>>> I tested with 2 PCD-50b's that I own. Both units will display
> the
> > > > > >>>> same
> > > > > >>>> error and both are definitely flashed for read/write access.
> The
> > > > > >>>> only
> > > > > >>>> jumper on each is the termination jumper. I have tried
> multiple CF
> > > > > >>>> cards, scsi cables, PCMCIA adapters and all give the same
> error.
> > > > > >>>> This
> > > > > >>>> is all done via the internal SCSI cable.
> > > > > >>>> For this sampler I am using Emax HD OS 1.1.
> > > > > >>>> Do I need to install the external kit for this to work or do I
> > > > > >>>> need to
> > > > > >>>> upgrade my Emax to a Plus or something? I assuming that this
> might
> > > > > >>>> have something to do with the original Connor HD being only
> 20mb's
> > > > > >>>> perhaps?
> > > > > >>>> If I need to provide more info, please let me know.
> > > > > >>>> Any guidance is greatly appreciated,
> > > > > >>>> Regards,
> > > > > >>>> -s*
> > > > > >>> [Non-text portions of this message have been removed]
> > > > > >>> Emax and Emax II User's Group Website
> > > > > >>> http://www.silveriafamily.comYahoo! Groups Links
> > > > > >> No virus found in this incoming message.
> > > > > >> Checked by AVG - www.avg.com
> > > > > >> Version: 9.0.914 / Virus Database: 271.1.1/3894 - Release Date:
> > > > > >> 09/13/11
> > > > > >> 07:35:00
> > > > > > Version: 9.0.914 / Virus Database: 271.1.1/3895 - Release Date:
> > > > > > 09/13/11
> > > > > > 19:35:00
> > Version: 9.0.914 / Virus Database: 271.1.1/3922 - Release Date: 09/27/11
> 07:34:00
