Emax
problem with internal HD
2011-10-05 by Aivis Mamajevs
Hi, what could be the fault? When I turn on the internal Quantum HD LCD read "not emax2 drive." Trying to format HD LCD read "scsi hardware error". I tried to connect to other HD, but it is the same.
Help please!
Aivis
Re: problem with internal HD
2011-10-05 by jaumemod
Dear folk, checking your SCSI ID , in EMAX SCSI 0 is reserved to floppy. Checking your default SCSI HD ID, must be 1 to 7.
Put terminator jumper on HD if it is in the end of SCSI chain.
In case you use a SCSI chain disconect other devices letting alone HD and tr y to format.
Emax OS won't start from removable media HD.
> Help please!
> Regards,
> Aivis
Re: [emax] Re: problem with internal HD
2011-10-06 by Ted Summers
That isn't entirely true.
While it is correct that on Emax 2 the SCSI ID cannot be 0 for the HD, I have Emax 1 and Emax 2 BOTH with SD card media and it boots from them.
If you have set the setting for SCSI ID in Emax 2 after booting once from floppy, from there you should be able to boot from that SCSI ID.
The 5380 SCSI controller in Emax is not smart enough to really know that a drive is a removable media or not, from my experience, or research.
Ted
> Help please!
> Regards,
> Aivis
2011-10-06 by Aivis Mamajevs
I tried all ways, set a scsi 0 and 1, but nothing changes,  Iomega jaz disc and the floppy disc can be formatted, but HD not. What other options are?
To: emax@yahoogroups.com
Sent: Thursday, October 6, 2011 5:19 AM
Subject: Re: [emax] Re: problem with internal HD
Ted
> Help please!
> Regards,
> Aivis
http://www.silveriafamily.comYahoo! Groups Links
You are setting the physical jumpers on the drive to 1 and then booting from
floppy and changing to ID 1 in the Emax2 menu, right?
Because if you do one without doing both, then it will never work.
> From: Ted Summers <djtbs1@...>
> Regards,
> Ted
> tr y to format.
> > Help please!
> > Regards,
> > Aivis
One jamper imposed on 1, and the other on the 5. This is IBM 540MB disc.
Sent: Thursday, October 6, 2011 7:00 PM
> Regards,
> Ted
> tr y to format.
> > Help please!
> > Regards,
> > Aivis
I would need to have a pic or exact detail of the jumpers and the drive
model to specifically verify you have the setting you expect.
Ted
> from
> disc
> > From: Ted Summers <djtbs1@gmail.com>
> a
> > Regards,
> > Ted
> > tr y to format.
> error".
> > > Help please!
> > > Regards,
> > > Aivis
pictures are not the best quality, but something that can already be seen.
Sent: Thursday, October 6, 2011 9:13 PM
Ted
> from
> disc
> a
> > Regards,
> > Ted
> > tr y to format.
> error".
> > > Help please!
> > > Regards,
> > > Aivis
Ted
> from
> disc
> a
> > Regards,
> > Ted
> > tr y to format.
> error".
> > > Help please!
> > > Regards,
> > > Aivis
pictures cannot be sent to the Emax group directly, you either have to
upload them to the files section or send them directly to a group member
email.
> Regards,
> Ted
> > from
> > disc
> are?
> I
> from
> that
> > a
> > > Regards,
> > > Ted
> floppy.
> and
> > > tr y to format.
> LCD
> > error".
> > > > Help please!
> > > > Regards,
> > > > Aivis
pictures have put under the Photo folder "Internal HD problem"
Sent: Thursday, October 6, 2011 11:15 PM
email.
> Regards,
> Ted
> > from
> > disc
> are?
> I
> from
> that
> > a
> > > Regards,
> > > Ted
> floppy.
> and
> > > tr y to format.
> LCD
> > error".
> > > > Help please!
> > > > Regards,
> > > > Aivis
2011-10-07 by Ted Summers
You need to move that jumper over to JP6.
According to the website here:
http://www.4drives.com/DRIVESPECS/IBM/1478.txt
You have the jumper for termination actually on "DISABLE UNIT ATTENTION".
That is the wrong place to have that jumper.
email.
> Regards,
> Ted
> > from
> > disc
> are?
> I
> from
> that
> > a
> > > Regards,
> > > Ted
> floppy.
> and
> > > tr y to format.
> LCD
> > error".
> > > > Help please!
> > > > Regards,
> > > > Aivis
2011-10-07 by Aivis Mamajevs
Sorry, but nothing changes :((( Maybe one of the chip is damaged?
Sent: Friday, October 7, 2011 4:58 AM
email.
> Regards,
> Ted
> > from
> > disc
> are?
> I
> from
> that
> > a
> > > Regards,
> > > Ted
> floppy.
> and
> > > tr y to format.
> LCD
> > error".
> > > > Help please!
> > > > Regards,
> > > > Aivis
Maybe the drive is bad, maybe bad SCSI cable.
You also haven't told us step for step what you have done.
If JP6 is on and JP1 is on, did you then:
boot from floppy
set SCSI ID in Emax2 menu for ID1
try format HD
Without exact steps and key touch, we cannot know that you have done all the
proper steps.
> email.
> seen.
> > Regards,
> > Ted
> > On Thu, Oct 6, 2011 at 9:24 AM, Aivis Mamajevs <pelecis@yahoo.com>
> disc.
> > > from
> jaz
> > > disc
> > are?
> HD,
> > I
> them.
> > from
> > that
> > > a
> > > > Regards,
> > > > Ted
> > floppy.
> > and
> > > > tr y to format.
> > LCD
> > > error".
> > > > > Help please!
> > > > > Regards,
> > > > > Aivis
