To: <emax@yahoogroups.com>
Sent: Wednesday, May 30, 2012 8:47 PM
Subject: RE: [emax] Re: Damaged Emax in transit. Need advice to get things
fixed.
Yes it does press a bit when tightened, but the buttons seem even on mine,
perhaps 1 or 2 mm are harder for me to gauge, I'll check, but I suspect you
are right. Still preferrable to me than doing irreversible mods to the PCB,
if I broke it I'd have to send it to you jammie!
To: emax@yahoogroups.com
Date: Wed, 30 May 2012 19:03:16 +0100
Subject: Re: [emax] Re: Damaged Emax in transit. Need advice to get things
fixed.
yes but it does press against the front panel when tightened
and the top buttons are set back farther
Sent: Wednesday, May 30, 2012 6:46 PM
fixed.
I put the VFD into my emax rack without any trace or PCB cutting, I just
used very thin insulated wires to wire it in and also to secure it in place.
Date: Wed, 30 May 2012 17:38:23 +0000
Subject: [emax] Re: Damaged Emax in transit. Need advice to get things
fixed.
I don't know yet which display I will go for but yes please =)
Thank you!
Kalle
--- In emax@yahoogroups.com, Chase Smith <plus_321@...> wrote:
> My friend replaced his displays with led lcds from crystalfontz. \ufffd I can't
> remember the exact ones and I think it may require a little work, but they
> look really nice and they're pretty cheap (I think around $20). \ufffd I can
> ask him for the part number or dimensions if you like.
> From: windefalk <kalle.windefalk@...>
> Sent: Wednesday, May 30, 2012 12:34 PM
> Subject: [emax] Damaged Emax in transit. Need advice to get things fixed.
> \ufffd
> Hi!
> I'm new to the group and new to using Emax. =)
> I received an faulty Emax 1 rack from a friend for about a month ago. It
> was shown (with Jammies help here on the forum) that the Echip possibly is
> dead, but there is a chance that a calibration can solve the problem!?
> I do not like to wait so I bought an Emax 1 SE keyboard a week ago. It
> was, according to the seller fully functional but has been damaged in
> transit.
> The damages are:
> 1) The display is dead. In the ad for the emax keyboard the seller
> described that E-mu factory had repaired the display which generated a
> noise (Inverter replacement?)
> From what I recall, Ted Summers said something about when the display is
> dead the Emax won't start. Maybe it's the LE Foil that's not working? But
> shouldn't one be able to read any characters then? The Emax rack's display
> is working. Well, the characters are shown but with no background light.
> I rather switch to a VFD but it seems to be a little work with that. Is
> there a replacement display to get somewhere? I don't wanna solder too
> much.
> 2) The keys Ab (third octave) to Db (5:th octave) generates no sound.
> However, it works to connect a MIDI keyboard to it and trigger all the
> notes. A funny thing is that on some sounds (loaded from disk), the D and
> Eb (5:th octave) generate sound but the voices "hangs" In most other sound
> banks they're dead as the other ones. It seems that only sounds with long
> decay, sustain and/or release are generated from the 5:th octave D and Eb.
> E, F, G #, G (5:th octave) do not work but the last A, A #, B is working.
> Any ideas?
> Regards
> Kalle
http://www.silveriafamily.comYahoo! Groups Links
