To: emax@yahoogroups.com
Sent: Tuesday, June 05, 2012 2:29 PM
Subject: [emax] Re: Can't copy OS to emax-formated DS DD disk with EMXP and/or Omniflop
I'm impressed of your knowledge Jammie!
I think the disk drive actually is replaced by the one Route66 sell.
I'll switch the disk drive with the other one and see if that will help. I live in Sweden and I'm not sure which OS i require =)
The OS that's displayed in Master/8/.. is 3.2.
The keyboard have an SE-sticker on it and a sticker for the new digital effects... not sure if that tells you if it's SE upgraded.
Can I check it somehow? The latest SE-version is 1.1 right? So i guess I don't have the upgrade since my emax display software version 3.2?
btw, I live in Sweden.
Jammie, do you have any solutions for sale? I'm about to send you my faulty boards and if you have CF-readers, working disks or whatever works, you could add that to the price for fixing the damn things AND test them together... If you would like to do that
/Kalle
--- In emax@yahoogroups.com, "jammie" <jammie.emma@...> wrote:
> sounds like a faulty write head on the disk drive
> try replacing the drive from the keyboard to the rack
> to see if you get the same errors
> not uncommon fr the original disk drives to fail
> ddsd disks would be better as hd disks need a stronger signal for the metal film type tape used
> the dd drive uses a smaller magnetic signal and on hd disks it can get written but comes up as garbage over time
> a hd drive has the same capability to write dd and hd disks thats what the second hole is for
> to switch between each mode no hole it will send out the magnetic field required to write to a dd disk
> if a hd disk is input then the dd field is switched off and the high mag feild is sent for writing
> your problem is most likely the read and write heads are misaligned
> meaning when reading a disk its fine but when writing a disk the head is off and fails to format disk
> where do you live and which os do you require as i can burn you a disk and send it
> From: windefalk
> Sent: Tuesday, June 05, 2012 12:18 PM
> Hi!
> I tried HD disks and covered the left hole (front towards me)but it's the same.
> I had a broken emax 1 rack and bought a emax SE keyboard with broken keys =) so I exchanged the analog board and the digital board with the boards from the SE-keyboard. The screen displays software version 3.2 or something like that (master/8/data slider in the bottom)
> /Kalle
> --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote:
> > You aren't using HD disks are you? If you are you have to cover the hole
> > (not the write protect one- the other one....)
> > What OS are you trying to write?
> > If your Emax is not SE and you attempt to load an OS with SE support it
> > won't load.
> > Also, same applies if you are trying to write an disk with HD support and
> > you don't have SCSI, you can get wrong OS also, I believe
> > On Mon, Jun 4, 2012 at 11:21 AM, windefalk <kalle.windefalk@>wrote:
> > > Hi E-Synthesist!
> > > I loaded a working sound disk into the emax and went to "Format Disk".
> > > Everything went well till I inserted the "destination" disk. The screen
> > > display "formatting.." Then I get the message "disk error". I've tried with
> > > 4 disks and now they can't load. "Bad Bank on disk".
> > > I also tried the "copy software" function with no success.
> > > When I loaded the disk that I had copied a sound bank to from EMXP it
> > > displayed something like "wrong os rev".
> > > I can format a disk in EMXP but can not write OS to the formated disk.
> > > I can write sounds (.em1) to an existing sound bank disk in EMXP.
> > > Regards
> > > Kalle
> > > --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
> > > > Actually there's no such thing as an Emax OS disk.
> > > > Any Emax floppy disk can contain both an OS and a soundbank.
> > > > Your floppy disks with OS 3.2 have the full OS on them, so after booting
> > > with these disks, it's perfectly possible to format another one. Just go to
> > > the Format module in the Emax, and when the module asks for the disk to be
> > > formatted, eject the OS 3.2 disk and insert an old or blank DSDD disk.
> > > > When Emax formats the disk, it will also copy the full OS to that disk,
> > > so after formatting you will have the OS-only disk.
> > > > When using EMXP, the format function will NOT copy an OS to the floppy
> > > disk, it will only format the sectors on the floppy.
> > > > So after formatting, the OS has to be copied as a seperate task.
> > > > That's what you seem to have been trying (if I understand you
> > > correctly), but you get that Windows error and the EMXP 89 error.
> > > > This EMXP error means that the floppy disk is NOT formatted in Emax
> > > format. The routine in EMXP which throws that error is also being used when
> > > EMXP wants to write a sound bank to the floppy disk.
> > > > So it seems you can not read/write anything to those formatted disks
> > > with EMXP (no OS, no sound bank).
> > > > I don't understand how you can get this 89 error if you have first
> > > successfully formatted the floppy disks for Emax. That's almost not
> > > possible.
> > > > ///E-Synthesist
> > > > --- In emax@yahoogroups.com, "windefalk" <kalle.windefalk@> wrote:
> > > > > Hi!
> > > > > Sorry. I wasn't clear enough!
> > > > > I have bootable sound disk floppys with OS (3.2) on them, yes!
> > > > > I thought you would need an emax OS-only disk to perform a disk format
> > > on the emax? Can I extract the OS from one of the sound disks to create a
> > > blank disk with OS in the emax?
> > > > > Yes. I can format factory new DS HD disks (I know they won't work but
> > > I had to try) and old DS DD disks (working sound disks) on the PC. Both in
> > > Omniflop and EMXP. I haven't tried to copy sounds on the emax itself. I
> > > look into it and get back with results. Thanks =)
> > > > > Yes, I can not write the OS to the formated disks with EMXP.
> > > > > Windows error message is:
> > > > > Exception Processing Message c0000014 Parameters 75b6bf7c 4 75b6bf7c
> > > 75b6bf7c
> > > > > next EMXP error message is:
> > > > > errorcode 89
> > > > > The capacity of the disk in drive A is not supported by EMAX samplers.
> > > > > The OS 3.2 file is an .EMX
> > > > > 262 kb large
> > > > > regards
> > > > > Kalle
> > > > > > Hi
> > > > > > You gave a lot of information about your problem but... the exact
> > > problem is still not clear to me.
> > > > > > - I understand you have floppy's from the seller containing the
> > > operating system 3.2 (each Emax sound disk normally also contains an OS).
> > > So you can boot the Emax, which means you can also format floppy disks in
> > > the Emax itself and copy the OS on the Emax itself.
> > > > > > Does that all work ?
> > > > > > - I understand you can format new DSDD disks for Emax on the PC with
> > > either OmniFlop itself or EMXP (using the OmniFlop driver. You can also
> > > copy sound banks to it (both in EMXP and on the Emax itself ("save bank")),
> > > correct ?
> > > > > > - Do I understand it correctly that you can NOT write OS (.EMX)
> > > files to these formatted floppy disks with EMXP ? If this is true, what
> > > error does EMXP give when trying to write an OS file to the floppy disk ?
> > > > > > ///E-Synthesist
> > > > > > > Hi Emax gurus!
> > > > > > > I have read through a lot of threads regarding this topic. It
> > > feels like I'm close to a solution but... anyway. Here are my attempts;
> > > > > > > 1) Got a IBM-PC laptop with floppy disk. This floppy is "on the
> > > fly" exchangeable with i.e. a cd-rom player. Forgot what they are
> > > called...cradle? Can this be a problem hence to the problems with
> > > USB-floppys? (I'm running XP). I read that one had a similar problem with
> > > the error code 89. I think it worked for him with another floppy. I will
> > > purchase an old computer tomorrow but "everything" works except for copying
> > > the OS to disk via EMXP
> > > > > > > 2) Latest versions of EMXP 2.11.2, omniflop v3.0
> > > > > > > 3) disabled antivirus program. no removable media plugged in.
> > > > > > > 4) I can format a DS DD disk to an emax disk. But i can't copy the
> > > OS to the disk. I have tried with OS 3.2 and SE 1.1 OS
> > > > > > > 5) I can copy banks and images to an already formated emax disk (I
> > > have like 10 floppys from the seller but no emax OS disk) and they work
> > > with the emax. The OS is 3.2 according to EMXP's "Manage OS" on those
> > > floppys. I can read, write and format those floppys in EMXP but i can't
> > > transfer the OS to a newly formated disk.
> > > > > > > 4)Omniflop "test installation" gives me 281 supported formats.
> > > When I run the "Diagnostics" and "test disk" I got the message "The format
> > > is recognized. You can read, write or re-format this disk" I can format a
> > > DS DD disk with omniflop.
> > > > > > > 5) I have read both manuals for EMXP and omniflop. Am I missing
> > > something?
> > > > > > > 6) I cannot format the disk in the emax without an Emax OS disk
> > > right?
> > > > > > > Someone got an idea?
> > > > > > > Regards
> > > > > > > Kalle Windefalk
> > [Non-text portions of this message have been removed]
