Emax
replacing power supply with one purchased from epr
2012-06-13 by llingo_apt
I cannot find a spot to hook up the voltage selector wires on this new power supply i just purchased from eps...everything is hooked up otherwise in their proper spot but these two wire locations seem to have no home!?
any help would be greatly appreciated
thanks
Re: [emax] replacing power supply with one purchased from epr
2012-06-13 by jammie
just put the 2 spades together and tape
they are not needed as the emax2 psu version was switchmode and auto sensing circuits for 110vac and 220-240vac
where as the emax version 1 psu had a switching transformer that could put the 110 dual inputs into series to make a 240 circuit via the switch on the back thats what the 2 red wires are for
they arnt needed and dont have any electrical connection on the new psu
  To: emax@yahoogroups.com
  Sent: Wednesday, June 13, 2012 11:09 PM
  Subject: [emax] replacing power supply with one purchased from epr
  thanks
Re: replacing power supply with one purchased from epr
I actually have a emax 1 ...so those are not needed at all for the new ps on the emax 1 either?  i tried pluggin it in and its not working properly..some rapid flashing and hmming, no fuse blown though.
>   ----- Original Message -----
>   From: llingo_apt
>   thanks
Re: [emax] Re: replacing power supply with one purchased from epr
2012-06-14 by Ted Summers
You probably have one of the two AC not connecting well- that can cause that behavior....
> From: llingo_apt
> thanks
2012-06-14 by llingo_apt
thanks- yeah i dunno...my blue and brown power cables seem to be solid as does my ground and pins...its not working at all....just squealing and lighting a few buttons up dimly...strange..can't figure it out i have a call in to epr we'll see i guess.
> > From: llingo_apt
> > thanks
