Emax
Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
2012-10-04 by loricruzer
I was hoping to get some additional advice or help with my Emax ?  I have an Emax 1 SE Plus (no internal HD). The Emax has factory SCSI interface ( PLus Model).
This is the scenario:
I bought the Emax SE Plus , very clean but no software included.
Then I bought a 1.1 Rev. boot disk .
The Emax booted and worked. The disk only had one test sample on it.
So now the Emax works, but I have no sounds.
I bought the Emax 1 library on Zip 100 disks
I then found out that my 1.1 OS would not support the SCSI interface.
I bought a correct 1.0 OS Floppy .
Now the Emax boots with 1.0 OS , then 'Transpose' button shows SCSI  ID is set at  0 . I try to change it to 5 (to match the Zip drive ID number).
The Emax will not let me change the SCSI number from 0 (zero).
That is my dilemma .  The Emax can not 'see' the Zip drive. The Zip drive's ID is not adjustable, it is set at 5  I think.  For some reason, the Emax won't allow me to change the SCSI ID number ,  I think it is supposed to be adjustable on the Emax ?
Can I get inside the Zip and change the ID to 0 (zero) ?  It is an Iomega Zip 100 Parallel Drive.  Or is my Emax not working correctly by not allowing me to change the SCSI number ?  Or maybe I'm doing something wrong ?
It seems that the 1.0 OS was made for an Emax SE Plus HD , my Emax does not have an HD, does that matter ?
Any help would be greatly appreciated.
Lori
Re: [emax] Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
2012-10-04 by jammie
plus os is for changing the scsi id to what ever you require this is for external drives which can be set to any other id than just 0 on the zips it has to be scsi 5
now the emax hd os will only see scsi id 0
so it wont see the zip disk at all
you need the plus os for that
now you will need to always use a floppy disk to load the os with a drive on scsi 5 becuase when the machine is switched of it looses all knowledge of this setting
and becuase it is a software switch you have to set it every time you boot the machine to scsi id 5 so that it can scan for the hd on that scsi id
now you need to make sure that the termination is on the external drive
  To: emax@yahoogroups.com
  Sent: Thursday, October 04, 2012 9:51 AM
  Subject: [emax] Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
  Lori
Re: Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
Hi Jammie,
First of all, thanks for taking time to address my problem. I understand everything you wrote, except the main issue is that the Emax will not let me change the SCSI ID number.
When I boot the unit with the 1.0 OS , then push and hold the 'Transpose' button, it displays SCSI 0 , then I try to change that number , Emax only responds to the keypad buttons when try to change the ID (I also tried the slider and the +/- keys), then says 'wait a moment' , but the display still shows 0 , no change.
The Emax acknowledges the request, says 'wait' but does not make the change, in a few seconds return to SCSI display, still shows SCSI 0.
Is there something wrong internally or am I doing something wrong? When I go to 'Master' , I did verify that the OS is 1.0 .
Please help if you can.
Also, since I am committed to keeping my Emax, I should get on the waiting list for the Oled thing but I'm not sure what it is ? I'll go back and read the posts regarding it. Can you briefly tell me what it is ? I think that once I get out of the woods with my Emax , I might need it down the line ?
Thanks again,
Lori
>   ----- Original Message -----
>   From: loricruzer
>   Hi,
>   Regards,
>   Lori
2012-10-04 by esynthesist
Lori,
In your original message you mention that the ZIP drive is a Parallel Drive.
This drive does not work with the Emax. Changing the SCSI ID on the Emax will not work. Unfortunately the connectors of both the SCSI version and Parallel version of the ZIP drive look the same (DB 25 pins) but they are not. I hope you didn't damage the Emax nor the ZIP drive by trying to connect them.
Anyway, with this kind of drive connected to the Emax, it's perfectly normal that the Emax does not recognize the drive on SCSI ID 5 or 6, so it keeps its SCSI ID setting on 0 until it finds a drive on 5 or 6.
You should buy a SCSI version of the ZIP drive, which has an adjustable SCSI ID (5/6 with a switch) if it is an external one (the famous blue cased one).
///E-Synthesist
--- In emax@yahoogroups.com, "loricruzer" <loricruzer@...> wrote:
> Hi Jammie,
> Thanks again,
> Lori
> >   From: loricruzer
> >   Hi,
> >   Regards,
> >   Lori
2012-10-05 by loricruzer
Hi Jammie,
Thanks again for your support. I'm learning.
I disconnected the Zip parallel drive (bad Lori), and I am in the process of buying the correct SCSI Zip drive from Ebay. I am also making sure that the SCSI cable is the correct one that is original to the drive. I'm not sure if it matters, but I'm thinking, if the drives are different, the cables might be different ?
Once I get the drive, I'll try again. Wish me luck !
It is my goal to eventually get up to snuff with all of the peripheral accessories and support gear for my Emax. My next thing is to try and use EMXP and OMNIFLOP , I just need to get an extra pc with an internal floppy and Windows XP.
I can't help but think that my whole SCSI zip drive thing is like neanderthal, but those are the only sounds that I have for now, the Emax 1 library on zip 100 disks. I'm thinking that once I learn how to use EMXP that should open up more options for samples and more efficient loading ?
I was reading the posts regarding the Oled, could someone tell me is it just a replacement backlight for my display? There is so much interest in it, I'm wondering if I need it for my Emax ?
Thanks again for any and all support.
Lori
--- In emax@yahoogroups.com, "esynthesist" <esynthesist@...> wrote:
> Lori,
> ///E-Synthesist
> --- In emax@yahoogroups.com, "loricruzer" <loricruzer@> wrote:
> > Hi Jammie,
> > Thanks again,
> > Lori
> > >   From: loricruzer
> > >   Hi,
> > >   Regards,
> > >   Lori
Re: [emax] Re: Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
2012-10-05 by Ted Summers
All the OLEDs are taken on the group buy.
The OLED is a complete replacement display.
Instead of LCD which you can't see at angles, the actual letters are made of LED's - there is no backlight.
The letters themselves are lighted.
Once you get the Zip disks into EMXP then get yourself a flash drive and drop the zip.
Just my opinion.
Thx,
Ted
On Oct 4, 2012, at 9:42 PM, loricruzer wrote:
Hi Jammie,
Lori
> Lori,
> ///E-Synthesist
> > Hi Jammie,
> > Thanks again,
> > Lori
> > > From: loricruzer
> > > Hi,
> > > Regards,
> > > Lori
Hi Ted,
Sounds good to me ! Once I get to the point of upgrading I'll take your advice and get the flash drive. I'll probably need some pointing in the right direction, since I don't have a clue about flash drives or how they work. In the meantime, I'll do my homework, learn as much as I can.
In regards to the backlight, will there be a future availability of the upgrade Oled ? If so, do I get on a waiting list now , or just wait. Another thing is that I was told that the regular backlight doesn't last very long, so does the upgrade last indefinitely ?
I had another question; Is it possible to have a midi in/out/through installed in an Emax ? I have to go back and forth changing the out/through setting on the Emax depending on how I want to route or generate signal with the rest of the midi components.
Lori
> Just my opinion.
> Thx,
> Ted
> Hi Jammie,
> Regards,
> Lori
> --- In emax@yahoogroups.com, "esynthesist" <esynthesist@> wrote:
> > Lori,
> > ///E-Synthesist
> > > Hi Jammie,
> > > Thanks again,
> > > Lori
> > > > From: loricruzer
> > > > Hi,
> > > > Regards,
> > > > Lori
2012-10-05 by jammie
all the drop in replacements are gone but
you can still fit the oled as you can wire point to point
its not hard to follow
you can also get a cf card reader and put it in an external case and that can be set to scsi ido
scsi zips are expensive for the second hand market and they are not reliable being second hand as they are getting old
i have had my share of the click of death i still own several zip100 and 250 and syquest ez flyer 230
but a nice quiet cf card reader you can use a nice 512mb cf card
  Sent: Friday, October 05, 2012 5:42 AM
  Subject: [emax] Re: Emax 1 SE Plus (non HD) SCSI Zip Drive Interface Problem
  Hi Jammie,
  Lori
  > Lori,
  > ///E-Synthesist
  > > Hi Jammie,
  > > Thanks again,
  > > Lori
  > > > From: loricruzer
  > > > Hi,
  > > > Regards,
  > > > Lori
The group buy is a one time thing.
Also- what is available today may not be what is on the market in 3 yrs or
even 2....
So you will most likely be on your own to replace your display in the
future.
LCD backlight / OLED last about 50,000hrs.
So it depends on your usage.
8hrs a day everyday is like 5-7 years.
If you don't use it that much- then it will last longer.
Someone else will have to address your midi questions.
I am not a midi guru.
Ask me about SCSI- I got answers.
Ask me about repairs / electronics- I got some answers also.
Thx,
Ted
On Fri, Oct 5, 2012 at 12:03 AM, loricruzer <loricruzer@...> wrote:
> Hi Ted,
> Thanks,
> Lori
> drop the zip.
> > Just my opinion.
> > Thx,
> > Ted
> > Hi Jammie,
> and Windows XP.
> > Regards,
> > Lori
> > > Lori,
> Drive.
> connect them.
> blue cased one).
> > > ///E-Synthesist
> > > > Hi Jammie,
> the line ?
> > > > Thanks again,
> > > > Lori
> scsi id
> drive
> > > > > From: loricruzer
> Problem
> > > > > Hi,
> it.
> interface.
> number).
> > > > > Regards,
> > > > > Lori
Hi Jammie,
You mentioned the Oled retrofit that I could use , I understand that the drop in replacements are all spoken for, that's ok.
So, how do I order/buy the Oled that requires wiring? Do I need to ask Ted ?
Color is not an issue for me, I don't see why the guys rather have white than yellow ?
If I purchase one, it is going to get put away for whenever it's time to have it installed. So, if it's easy to order and I don't step on anyone's toes, then I'll purchase it. Just let me know how to go about it.
I noticed that the drop in replacements came and went fast ! So for future references, how do you stake your claim, just post on here that you're interested ?
Thanks ,
Lori
>   From: loricruzer
>   Hi Jammie,
>   Regards,
>   Lori
>   > Lori,
>   > ///E-Synthesist
>   > > Hi Jammie,
>   > > Thanks again,
>   > > Lori
>   > > > From: loricruzer
>   > > > Hi,
>   > > > Regards,
>   > > > Lori
i get mine from rapid online
they have
yellow on black
white on black
green on black
navy blue on black
red on black
its the 16x2 oled display
they are £26 delivered including taxes
  Sent: Friday, October 05, 2012 7:14 PM
  Hi Jammie,
  Thanks ,
  Lori
  > From: loricruzer
  > Hi Jammie,
  > Regards,
  > Lori
  > > Lori,
  > > ///E-Synthesist
  > > > Hi Jammie,
  > > > Thanks again,
  > > > Lori
  > > > > From: loricruzer
  > > > > Hi,
  > > > > Regards,
  > > > > Lori
2012-10-05 by Tony Court
I actually purchased an unused/sealed external Iomega zip100 SCSI drive off
e-bay a few weeks ago. It was still boxed and sealed when I received it.
It's a US model running at 120v - I'm not sure if it would be suitable for
you? I only need it to transfer some sounds from zip disks to CF. I would
be happy to sell it on for the price I paid for it plus shipping as I will
only have used it for a couple of weeks by the time I'm done with it.
The original e-bay listing is here:
http://www.ebay.com/itm/280960544798and shows the price (and shipping)
that I paid for it.
If you're interested, let me know.
Tony
> From: loricruzer
> Problem
> Hi Jammie,
> and Windows XP.
> Regards,
> Lori
> > Lori,
> Drive.
> connect them.
> one).
> > ///E-Synthesist
> > > Hi Jammie,
> the line ?
> > > Thanks again,
> > > Lori
> scsi id
> drive
> > > > From: loricruzer
> Problem
> > > > Hi,
> > > > Regards,
> > > > Lori
2012-10-06 by loricruzer
Hi Tony,
First of all, thanks for the offer, I'm definitely interested.
When will your unit be available ? I can't tell you how bad I want my Emax to get up and running with some sounds. So,if yours is available now, that's good, but if you need a couple weeks more to do your transfers, then I'll pass.
I am currently bidding on two drives on Ebay, set to end this weekend. I'm determined to win one of them. The good thing is that my max bid is low, so if I don't do the last second bid again thing, I'll probably lose.
If your drive is available now, then how would I go about buying it ? Actually, I'd like to know how do you buy anything on this forum ? I can't post my personal info. here , so how do you guys buy sell and trade stuff ?
Let me know. The good thing about yours is that it's relatively new and it works, already tested.
Also, if I do purchase it, I'll pay via PayPal. The only thing I ask is that, I pay you right away,you ship it out right away.
Thanks again for the offer.
Lori
> that I paid for it.
> Tony
> > From: loricruzer
> > Problem
> > Hi Jammie,
> > and Windows XP.
> > Regards,
> > Lori
> > > Lori,
> > Drive.
> > connect them.
> > one).
> > > ///E-Synthesist
> > > > Hi Jammie,
> > the line ?
> > > > Thanks again,
> > > > Lori
> > scsi id
> > drive
> > > > > From: loricruzer
> > Problem
> > > > > Hi,
> > > > > Regards,
> > > > > Lori
2012-10-06 by Tony Court
Hi Lori,
I'll be in a position to ship the zip drive, in its original box with all accessories, on Monday. I can get my zip disks transferred over the weekend. It just requires me to actually learn how to use everything..... I only got my Emax II working today!
I have a PayPal account so that works out perfectly.
Let me know what you would like to do, and obviously if you randomly win one on e-bay first I completely understand!
Tony
On Oct 5, 2012, at 19:42, "loricruzer" <loricruzer@...> wrote:
> Hi Tony,
> Regards,
> Lori
> > that I paid for it.
> > Tony
> > > From: loricruzer
> > > Problem
> > > Hi Jammie,
> > > and Windows XP.
> > > Regards,
> > > Lori
> > > > Lori,
> > > Drive.
> > > connect them.
> > > one).
> > > > ///E-Synthesist
> > > > > Hi Jammie,
> > > the line ?
> > > > > Thanks again,
> > > > > Lori
> > > scsi id
> > > drive
> > > > > > From: loricruzer
> > > Problem
> > > > > > Hi,
> > > > > > Regards,
> > > > > > Lori
Hi Tony,
Why not check back with me when you get done with it, and by that time if I haven't managed to get one, then we can work something out.
I saw the original transaction, the price is fine.
I also noticed that you are new to this forum, welcome, I recently joined also. Really nice people here and very knowledgeable.
I'm curious about your transfer project, good luck ! I'll be in the same boat soon enough. Save your notes.
I'm glad to hear you got your Emax II running, congrats !
Lori
> Hi Lori,
> Tony
> > Hi Tony,
> > Regards,
> > Lori
> > > that I paid for it.
> > > Tony
> > > > From: loricruzer
> > > > Problem
> > > > Hi Jammie,
> > > > and Windows XP.
> > > > Regards,
> > > > Lori
> > > > > Lori,
> > > > Drive.
> > > > connect them.
> > > > one).
> > > > > ///E-Synthesist
> > > > > > Hi Jammie,
> > > > the line ?
> > > > > > Thanks again,
> > > > > > Lori
> > > > scsi id
> > > > drive
> > > > > > > From: loricruzer
> > > > Problem
> > > > > > > Hi,
> > > > > > > Regards,
> > > > > > > Lori
Hi Lori,
As soon as I've finished transferring everything I'll let you know and we can take I from there :)
Thanks
Tony
On Oct 6, 2012, at 1:55, "loricruzer" <loricruzer@...> wrote:
> Hi Tony,
> Regards,
> Lori
> > Hi Lori,
> > Tony
> > > Hi Tony,
> > > Regards,
> > > Lori
> > > > that I paid for it.
> > > > Tony
> > > > > From: loricruzer
> > > > > Problem
> > > > > Hi Jammie,
> > > > > and Windows XP.
> > > > > Regards,
> > > > > Lori
> > > > > > Lori,
> > > > > Drive.
> > > > > connect them.
> > > > > one).
> > > > > > ///E-Synthesist
> > > > > > > Hi Jammie,
> > > > > the line ?
> > > > > > > Thanks again,
> > > > > > > Lori
> > > > > scsi id
> > > > > drive
> > > > > > > > From: loricruzer
> > > > > Problem
> > > > > > > > Hi,
> > > > > > > > Regards,
> > > > > > > > Lori
