Interal Atapi IDE ZIP drive possible on EMAX rack?
2013-03-15 by d0ct0rgr33nthum8
Hi all, I am wondering if the above is possible, and if so- do I need any extra equipment or can i just install the ZIP straight into the Emax? Apologies if this has been posted already- I did a quick search but I have very limited time this evening. Thanks!
2013-03-15 by Ted Summers
EMAX only has SCSI interface. You can get an ACARD 7220 / 7222, but they are very expensive. Easier to get SCSI interal zip, for the price, or get media drive like PCD-60B or 50B. On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < wagwan.drgreenthumb@...> wrote: > ** > > > Hi all, > > I am wondering if the above is possible, and if so- do I need any extra > equipment or can i just install the ZIP straight into the Emax? > > Apologies if this has been posted already- I did a quick search but I have > very limited time this evening. > > Thanks! > > > [Non-text portions of this message have been removed]
Thanks. Will an internal SCSI zip will go straight in replacement of the floppy drive? Same for media drive? --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote:
> > EMAX only has SCSI interface. > You can get an ACARD 7220 / 7222, but they are very expensive. > Easier to get SCSI interal zip, for the price, or get media drive like > PCD-60B or 50B. > > > > On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < > wagwan.drgreenthumb@...> wrote: > > > ** > > > > > > Hi all, > > > > I am wondering if the above is possible, and if so- do I need any extra > > equipment or can i just install the ZIP straight into the Emax? > > > > Apologies if this has been posted already- I did a quick search but I have > > very limited time this evening. > > > > Thanks! > > > > > > > > > [Non-text portions of this message have been removed] >
Do i need a scsi kit or something? --- In emax@yahoogroups.com, "d0ct0rgr33nthum8" <wagwan.drgreenthumb@...> wrote:
> > Thanks. > > Will an internal SCSI zip will go straight in replacement of the floppy drive? > > Same for media drive? > > --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote: > > > > EMAX only has SCSI interface. > > You can get an ACARD 7220 / 7222, but they are very expensive. > > Easier to get SCSI interal zip, for the price, or get media drive like > > PCD-60B or 50B. > > > > > > > > On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < > > wagwan.drgreenthumb@> wrote: > > > > > ** > > > > > > > > > Hi all, > > > > > > I am wondering if the above is possible, and if so- do I need any extra > > > equipment or can i just install the ZIP straight into the Emax? > > > > > > Apologies if this has been posted already- I did a quick search but I have > > > very limited time this evening. > > > > > > Thanks! > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > >
2013-03-15 by Nik Kinloch
It depends what version of the Emax you have. Emax -> no SCSI Emax SE -> no SCSI Emax HD -> you have SCSI Emax HD SE -> You have SCSI Emax Plus -> Think you have SCSI There is a bunch of info on the net and in this group about it. You can sometimes upgrade non-SCSI Emax's to SCSI, but it depends on the motherboard version.
On 15/03/2013 19:29, d0ct0rgr33nthum8 wrote: > Do i need a scsi kit or something? > > --- In emax@yahoogroups.com, "d0ct0rgr33nthum8" <wagwan.drgreenthumb@...> wrote: >> Thanks. >> >> Will an internal SCSI zip will go straight in replacement of the floppy drive? >> >> Same for media drive? >> >> --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote: >>> EMAX only has SCSI interface. >>> You can get an ACARD 7220 / 7222, but they are very expensive. >>> Easier to get SCSI interal zip, for the price, or get media drive like >>> PCD-60B or 50B. >>> >>> >>> >>> On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < >>> wagwan.drgreenthumb@> wrote: >>> >>>> ** >>>> >>>> >>>> Hi all, >>>> >>>> I am wondering if the above is possible, and if so- do I need any extra >>>> equipment or can i just install the ZIP straight into the Emax? >>>> >>>> Apologies if this has been posted already- I did a quick search but I have >>>> very limited time this evening. >>>> >>>> Thanks! >>>> >>>> >>>> >>> >>> [Non-text portions of this message have been removed] >>> > > > > ------------------------------------ > > Emax and Emax II User's Group Website > > http://www.silveriafamily.comYahoo! Groups Links > > >
you might need a kit, depends- check my site: http://djtbs1.wordpress.com/2011/09/15/scsi-kit-do-i-need-one/ http://djtbs1.wordpress.com/2010/10/04/scsi-kit-images/ -T On Fri, Mar 15, 2013 at 12:29 PM, d0ct0rgr33nthum8 < wagwan.drgreenthumb@...> wrote: > ** > > > Do i need a scsi kit or something? > > > --- In emax@yahoogroups.com, "d0ct0rgr33nthum8" <wagwan.drgreenthumb@...> > wrote: > > > > Thanks. > > > > Will an internal SCSI zip will go straight in replacement of the floppy > drive? > > > > Same for media drive? > > > > --- In emax@yahoogroups.com, Ted Summers <djtbs1@> wrote: > > > > > > EMAX only has SCSI interface. > > > You can get an ACARD 7220 / 7222, but they are very expensive. > > > Easier to get SCSI interal zip, for the price, or get media drive like > > > PCD-60B or 50B. > > > > > > > > > > > > On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < > > > wagwan.drgreenthumb@> wrote: > > > > > > > ** > > > > > > > > > > > > Hi all, > > > > > > > > I am wondering if the above is possible, and if so- do I need any > extra > > > > equipment or can i just install the ZIP straight into the Emax? > > > > > > > > Apologies if this has been posted already- I did a quick search but > I have > > > > very limited time this evening. > > > > > > > > Thanks! > > > > > > > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > > > > [Non-text portions of this message have been removed]
also- the floppy drive is not SCSI and Emax expects the floppy drive to be there (unless you jumper it, but that isn't my recommendation). -T On Fri, Mar 15, 2013 at 11:43 AM, d0ct0rgr33nthum8 < wagwan.drgreenthumb@gmail.com> wrote: > ** > > > Thanks. > > Will an internal SCSI zip will go straight in replacement of the floppy > drive? > > Same for media drive? > > --- In emax@yahoogroups.com, Ted Summers <djtbs1@...> wrote: > > > > EMAX only has SCSI interface. > > You can get an ACARD 7220 / 7222, but they are very expensive. > > Easier to get SCSI interal zip, for the price, or get media drive like > > PCD-60B or 50B. > > > > > > > > On Fri, Mar 15, 2013 at 10:53 AM, d0ct0rgr33nthum8 < > > wagwan.drgreenthumb@...> wrote: > > > > > ** > > > > > > > > > Hi all, > > > > > > I am wondering if the above is possible, and if so- do I need any extra > > > equipment or can i just install the ZIP straight into the Emax? > > > > > > Apologies if this has been posted already- I did a quick search but I > have > > > very limited time this evening. > > > > > > Thanks! > > > > > > > > > > > > > > > [Non-text portions of this message have been removed] > > > > > [Non-text portions of this message have been removed]
2014-06-15 by niklas.ehrlin@...
2014-06-15 by Robert Van Kuran
As long as you can set the internal Zip to SCSI Device 0 when your SCSI HDD is not present, then you can boot from SCSI. In my case I have modded my Emax to have external SCSI w/ an external Zip Drive which can only be set to SCSI Device ID 5 or 6. So I must still boot the Emax Plus 1.0 OS from the FDD because SCSI Device ID 0 is needed to be present in order to boot via SCSI. Once booted then I can load banks from any SCSI by setting the Emax SCSI ID to read Device ID 5 or 6 for my external Zip drive by pressing the Transpose and then the number pad buttons to select. Hope that helps. -RVK
> On Jun 15, 2014, at 4:25 AM, "niklas.ehrlin@... [emax]" <emax@yahoogroups.com> wrote: > > And forgot to mention that this is a SCSI version that I have of the Zip-drive. > > Niklas >
Sorry I just noticed this was a post for IDE... -RVK
> On Jun 15, 2014, at 4:46 AM, "Robert Van Kuran guitar5l50@... [emax]" <emax@yahoogroups.com> wrote: > > As long as you can set the internal Zip to SCSI Device 0 when your SCSI HDD is not present, then you can boot from SCSI. > > In my case I have modded my Emax to have external SCSI w/ an external Zip Drive which can only be set to SCSI Device ID 5 or 6. So I must still boot the Emax Plus 1.0 OS from the FDD because SCSI Device ID 0 is needed to be present in order to boot via SCSI. > > Once booted then I can load banks from any SCSI by setting the Emax SCSI ID to read Device ID 5 or 6 for my external Zip drive by pressing the Transpose and then the number pad buttons to select. > > Hope that helps. > > -RVK > >> On Jun 15, 2014, at 4:25 AM, "niklas.ehrlin@... [emax]" <emax@yahoogroups.com> wrote: >> >> >> And forgot to mention that this is a SCSI version that I have of the Zip-drive. >> >> Niklas > >
2014-06-15 by Niklas Ehrlin
I was actually asking for the SCSI version, sorry to post in wrong topic... And thanks for your answer, helped alot! Slowly all things are starting to get clearer regarding my EMAX.. ;)
-RVK
On Jun 15, 2014, at 4:46 AM, "Robert Van Kuran guitar5l50@yahoo.com [emax]" <emax@yahoogroups.com> wrote:
As long as you can set the internal Zip to SCSI Device 0 when your SCSI HDD is not present, then you can boot from SCSI.In my case I have modded my Emax to have external SCSI w/ an external Zip Drive which can only be set to SCSI Device ID 5 or 6. So I must still boot the Emax Plus 1.0 OS from the FDD because SCSI Device ID 0 is needed to be present in order to boot via SCSI.Once booted then I can load banks from any SCSI by setting the Emax SCSI ID to read Device ID 5 or 6 for my external Zip drive by pressing the Transpose and then the number pad buttons to select.Hope that helps.
-RVKAnd forgot to mention that this is a SCSI version that I have of the Zip-drive.
Niklas
