multiple exs controlled by protools via midi?
2004-01-16 by kotitek
hi, does anybody know the solution for my problem? I'm using Pro Tools with an Unitor 8 midi interface. To use the exs 24 I connect another computer with an mt4 and Logic 4.7 to the system. In Logic I'm using the exs 24 which receives the midi signals from Pro Tools. So far it works perfect........---but. It's not possible to assign and playback or record e.g. 24 midi channels to 24 audioinstruments and record or playback them. Logic records only to a selected track but Its not possible to select e.g. 24 tracks .......as I said: I can't believe that such a powerfull sequencer as logic does have such a limitation. Is there anybody knowing a solution for my problem?? thanx matt
