Re: [EXS] is this a known EXS24 bug?
2004-07-02 by Sascha Franck
rcrofty2k wrote:
> In both OS 9.2.2 and Panther, I have a weird EXS24 problem. I have the +/-
keys set in
> key commands to lengthen/shorten a notes duration by +/- a SEMPTE frame
when editing
> midi in the Matrix window. When I perform this edit on an EXS24 track
(with the EXS main
> panel open on desktop) it will open the EXS instrument select popup and
often scroll to
> the next folder in the menu (based on wether I've pressed the + or - key)
and sometimes
> it actually will change the instrument. eventually the EXS popup menu
closes and the
> desired note length edit is successfully done. this never happens on
non-EXS24 tracks. is
> this a known bug?
From what I know, some keycommands are "hardwired" to some plugin functions.
This might be one of those. I'm almost sure it will only happen if the EXS
is your focussed window, right?
Sascha
2004-07-02 by rcrofty2k
> Sascha
not exactly, it happens when I'm working in the Matrix edit window of the (opened) EXS
instance in question.
I've double checked for redundant key command assignments and there are none, which is
why I'm wondering if it is a bug. I'm aware that you can assign key commands to EXS edit
window functions but as I understand the new EXS manual - there are no preset key
commands for the EXS front panel - just midi cc type stuff.
2004-07-03 by Sascha Franck
rcrofty2k
preset key
I know - that's why I used the term "hardwired" in my post. Eventually you
just can't switch this off...
On Windows for example (which I am still using mainly), the numeric +/- keys
of the ES2 are assigned to parameter in/decrease, allways valid for the last
"touched" parameter. That's why I thought it could be similar with your EXS
problem.
Sascha
