Re: [EXS] Multiple-output woes
2004-08-21 by Sascha Franck
Tony Maxwell wrote: > 1. It seems that all my sequences have to be on the track with the actual EXS instrument (I > can't place the individual drum sequences (i.e. snare, hat, etc.) on the aux tracks. This > makes it hard to edit the sequences, since they are all piled on top of each other. Aux objects are no instrument-like objects (in Cubase things are treated a bit differently as you can at least play multitimbral instruments on their appropriate tracks in your project window). So, in case you want your sequences on separate tracks in your arrange, just duplicate the main EXS instrument track and place them on there. You may want to use the trackname function to give them appropriate names. > 2. Looping only seems to work for the first sequence on the track. If I record a 1-bar kick > sequence, I can loop that, and the loop will play. But if I then record a 1-bar snare > sequence on top of that and try to loop it, only the kick sequence loops. That's normal. In case you want the snare sequence to loop as well you will have to either merge it with the kick sequence or place it on another track using the same instrument. Looped sequences can only loop one sequence, not a bunch of them placed on top of each other - and maybe that's just clever because in the middle of a multiple-sequence-looped part your visual orientation would just get lost. In case you want to treat different sequences as one part that you can loop, pack them into a folder, then drag the resulting file onto the EXS track in question (you can even delete the folder track after that). Regards, Sascha
