Instrument change
2004-11-10 by Jake Holmes
Maybe this time someone will listen to my plight. Maybe three times is the charm. In L6 I was able to change instrument (Previous/Next) in a sequence by going to the exs preferences and entering a note number in the "number fields. I have tried to do the same in L7 and it doesn't work . Would someone please try this function to see if they can get it to work. Pitch bend will change an instrument so I know the function still works on some level. I offer up the clear and concise instructions in the manual as evidence that this particular function doesn't warrant much informational insight. "Previous/Next Instrument Previous/Next Instrument and the number fields alongside determine which MIDI event type (and data value) will be used for selection of the previous or next Instrument: Note, Poly Pressure, Control, Program, Channel Pressure, Pitch Bend. In the number field (depending on the event type), either the Note Number or the value of the first data byte can be entered. When Control is selected, the number field determines the Controller number. " Not for me... If "poly pressure" is "note pressure" that also doesn't work and what is "Channel Pressure?" If nobody knows or cares about this possible bug just let me know your out there. I feel so alone in my confusion. Logic 7 g5 dual Panther
