Redmatica EXSManager Pro: Issues and Help
2005-01-04 by Aaron Rosenberg
Hey EXS and EXSManager fans, I know the time-honored notion of RTFM, so
I did. But after all was said and done I managed to send all of my
Native Instruments WAV/AIFF files to a random directory and pull them
out of their homes forcing me to install the libraries again. There were
also a ton of instruments in the red. Sad to say, the $99 application
with my misunderstanding or whatever has made my life more difficult
instead of easier.
The basic point is I have .exs and samples all over my machine
(different directories, drives, etc.). How can I easily move all
non-duplicate .exs instruments into my sampler instruments folder and
move the respective samples into directory x. For such a helpful, simple
application, I'm find this to be a difficult task. God knows why. Any
help is greatly appreciated. Am I supposed to use Logic Project Manager
in conjunction with it?
Thanks, Aaron
Re: [EXS] Redmatica EXSManager Pro: Issues and Help
2005-01-04 by James Ryan
> From: Aaron Rosenberg <aaron@...>
> Reply-To: <exs-users@yahoogroups.com>
> Date: Tue, 04 Jan 2005 12:01:27 -0500
> To: "logic-users@yahoogroups.com" <'logic-users@yahoogroups.com'>,
> "exs-users@yahoogroups.com" <'exs-users@yahoogroups.com'>
> Subject: [EXS] Redmatica EXSManager Pro: Issues and Help
> instead of easier.
> Thanks, Aaron
Send this request to Andrea at Redmatica.  I did the same thing and he
walked me through it.  It's not that difficult a job to repair.  His email
address is agoz@....
2005-01-04 by Mitchell DeFreytas
Open your Mac HD, and up in the right corner, if you
are all upgraded in OSX, do a search in the 'local
disks' box.  This should pull up all those files in
the designated folder.  Then you can move them where
you want them.
Mitchell
2005-01-04 by Peter Ostry
> were
> instead of easier.
I believe the instruments turned to red because they lost their sample
location and were incomplete. Will you beat me if I say that you most
likely can repair that by setting the sample directory to a higher
hierarchical level and run the program again?
Second hint: before you reorganize the next time, empty the trash and
check the option "Also references to trash" on top of the ExsManager's
main window. And go to the "General" page - be sure that "Files deleted
are sent to trashcan" is selected. This will help you if you accidently
delete samples with ExsManager because the files in the trash remain
referenced.
> simple
Excuse the length of the description below, I simply think it can help
you to avoid the same trap you are in...
ExsManager cannot move instruments except from sample directories to
the one and only "Sample Instruments" directory you've set. If you have
more than one instrument directory now, I think the additional ones
were created during reinstallation of the libraries.
The program cannot help you recreating instruments. It's job is to
organize samples according to instruments. So you have to rebuild the
instrument structure from scratch. This is the time to rethink the
organization. If you don't mind I tell you how I did it after several
trials and errors:
===== first my stuff =====
I do not merge libraries. Not in the instrument folder and not the
samples - I feel uneasy if everything is mingled :) - so I have the
following:
Sampler Instruments
     Logic
         01 Piano
         02 Guitars
         ...and all others...
     PMI
         Emperor
         Old Lady
     Sampleheads
         Bass
             Fender Precision
             ...and others...
         Drums
...and so on...
Sampler Library
     Logic
         ...Samples...
     PMI
         Emperor
             ...Samples...
         Old Lady
             ...Samples...
...and so on...
In ExsManager this structure allowes to select a single library folder
as instrument directory and a single folder as "aux dir" were the
sample files go. For example if I want to rebuild the Old Lady, I set
"Sampler Instruments/PMI/Old Lady" as instrument directory and "Sampler
Library/PMI/Old Lady" as aux directory. I never lost control since I do
it that way. And it is fast.
"Sampler Instruments" and "Sampler Library" are located in a folder
"Samples" in my home directory.
===== now your part =====
Make a finder search to locate all instrument folders you have. Combine
them (by hand) to a single directory in the structure you want, in a
new folder called "Sampler Instruments", located anywhere on your disk.
If you are ready, you have three choices to put this folder:
#1
/Library/Application Support/Logic/
This is the root level, some installers put their files here.
#2
~/Library/Application Support/Logic/
This is your user level, some installers put their files here (yes,
here also...)
#3
Anywhere on your disk.
In case you choose #2 or #3 put an alias of your new folder into #1. So
Logic will find the instruments. To be sure, open Logic and test your
hierarchy. Most likely it will not play, but you see what you have
done.
Now create a Folder "Sampler Library" anywhere. Create folders inside
to reflect the instrument structure (not the full depth, two levels are
usually enough).
Open Exsmanager.
If your samples are really all over the machine then set the [Sample
dir] to the highest level: "/".
Set one of your directories of your new instrument folder as [Inst dir].
Set [Aux (dest) dir] to the correspondending folder in your "Sampler
Library" folder.
For the first run use "Samples are moved when reorganizing" and set the
other choices to "Moved to ... (maintain hierarchy)". Now analyze and
see what ExsManager says. If you are happy, process. Check the "Sample
Libraries" folder.
Carry on, step by step, until all your samples are at home. Then you
can test them in Logic and - if you want - reorganize the instruments,
run Exsmanager again on the same folders the files are in. Don't forget
to set the [Sample dir] to the folder where the samples now are - that
makes things very fast.
Last hint:
If you have problems moving or changing files on root level because of
permissions, you can download the small Application "chop" from Apple.
Open it, set the permissions to "777" if you are the only one on this
machine and do not care about permissions. Afterwards you can drop any
folder onto "chop" and the permissions are recursively released.
Good luck!
Peter Ostry
2005-01-05 by Andrea at Redmatica
Hello,
i just noticed this thread and would like to comment a couple of things.
> Hey EXS and EXSManager fans, I managed to send all of my
You could have repaired your actions by using ExsManager built-in
"Restore" function. Before any operation, a "snapshot" of your file
locations is automatically saved (unless you disable it!) so that you
can go back to the starting situation.
This ("It's job is to organize samples according to instruments") is
partially true. But the trick here is to use the "move instruments out
of sample dir" function to grab all .exs instruments from a volume or
even the entire system, and move them to a single folder. Just ignore
the samples for a moment:
-set SampleDir to where your "disorganized" .exs instruments are (can
be a folder, volume, also all the system)
-set InstDir to where you want them all to be
-set "Instruments in SampleDir are" to "Moved to InstDir and relinked
(using hierarchies)" in the "Instruments" tab
- analyze and process
At this point all the .exs files that previously were in the
"SampleDir" folder/volume will be automagically moved inside your
InstDir.
Be careful in not moving song projects' .exs files or garageband
instruments in this way.
> organization....
> ....In ExsManager this structure allowes to select a single library
> folder
This is an acceptable method, but you can do it in a faster/simpler
way. Once you have a satisfying instrument folder structure, you can:
- set InstDir to your whole Instrument Folder
- set SampleDir to your whole sample folder
- turn on Samples Reorganization to "Use InstDir structure in SampleDir"
- you might want to enable clone and unused processing too
Now every time you analyze and process, all samples inside SampleDir
will be checked and automatically moved to their right folders, for all
instruments  at once, so that you can add samples quite randomly and
ExsManager will take care of everything. A click on "Clean" for the
SampleDir after each processing will also remove the unused folders
that you might have created when moving the disorganized  samples
there.
Best Regards
Andrea at Redmatica
Re: Redmatica EXSManager Pro: Issues and Help
2005-01-05 by steinway03
> Thanks, Aaron
Aaron, have  you tried getting in touch with Andrea at Redmatica?  If you tell him exactly
what you did and what happened, he has a track record of doing his best.  He's sent me
detailed EXS-surgery instructions even including jpgs of what the screen should look like
before or after a given step in the procedure.  And his procedures have worked.
Larry
Dr L's Music   dr_l_music@...m
G4 733MHz 1.2GB RAM  L7 -- OS 10.3.latest, L5.5.0 -- OS9
accompanying - arranging - composition - lessons - live performance
CD production - from backup piano to full band with vocals
Check out the pop epic Cupid 911:  http://www.cupid911.com or http://
www.cdbaby.com/cd/drllilarose
Listen to Dr L's internet radio station: http://www.live365.com/stations/dr_l_
Using Redmatica EXSManager Pro with 7.1
2005-06-10 by revDAVE
I would like to relink my exs samples after upgrading to 7.1.
 Most of the relinking went fine,  but I think I might have  messed some
stuff up regarding -  the new factory sounds ...  I believe some of the new
factory sounds samples are stored in two places the logic folder and also
some are also in the garage band folder ...
Q:  How do I correct this situation -  since I think all the sample
Instruments are stored together but the samples are in these two different
folders?
Thanks - RevDave
CoolCat@...
[db-lists]
Re: [EXS] Using Redmatica EXSManager Pro with 7.1
2005-06-10 by Colin Shapiro
>folders?
In addition to selecting a "main" sample folder, you can set any
number of other folders in <Paths>
Please check the manual on exactly how to do this.
Regards - Colin
2005-06-11 by revDAVE
> Regards - Colin
Thanks - that worked!
Now I see that there  are some instruments -  in the garage band samples
folder like Alto Sax -  that  do not have a suffix -  so they're listed
simply as documents -  and therefore the EXS manager doesn't seem to be able
to fix them...
-  are these samples screwed up somehow - because they don't say .aif -  I
am afraid to change the name and add the suffix -  because maybe garage band
will get screwed up and not see them anymore
Q:  how can I fixed this?
[db-lists]
2005-06-14 by Colin Shapiro
Good - you're welcome.
>to fix them...
I remember that when I ran EXS Manager I also had some funny problems
with certain Garageband files. Because the instruments were so small
(unlike Vienna Library for example) they load quickly in EXS24 or
Garageband, so I just left them alone.
Sorry I can't help more.....
Regards - Colin
2005-06-17 by Andrea at Redmatica
> samples
> listed
> to be able
> to fix them...
> say .aif -  I
> garage band
There's an option in ExsManager (Options/Scan/Also scan files without
suffix) that will make EM recognize these files too.
You can also enable "Fix filename extensions for samples" and the
samples will be renamed with the correct suffix (.aif, .wav, etc) for
you automatically.
Best Regards
Andrea at Redmatica
2005-06-19 by Colin Shapiro
>you automatically.
Thanks for that Andrea - I'd forgotten about that option.
Regards - Colin
