Using Precisionsound sample in Logic?
2005-05-06 by Mark Falchook
Greetings all,
I would really like to use the Precisionsound drum samples from this
downloadable library in Logic:
http://www.store.precisionsound.net/treated2info.php
But they are PC folk, and only have the samples in HALion, Kontakt, NN-XT
and Battery formats. Any thoughts on how to get these samples into Logic;
preferably EXS24?
-Mark
Re: [EXS] Using Precisionsound sample in Logic?
2005-05-06 by Peter Ostry
> NN-XT
> Logic;
> preferably EXS24?
If there is no better way, here is mine:
The multisamples are .wav files, so you can directly load them into the
EXS instrument editor. But then it is going to be tedious. Hopefully
the samples have meaningful names. You have to setup zones for the
velocity samples, means you reorder them in a way that samples
belonging to a key are positioned under that key in the editor. And you
have to decide which sound you want on which key.
Afterwards you set up groups with velocity ranges. If you do not have
information about the velocities at which the samples are expected to
sound, you have to guess and setup the groups by intention. Finally you
save that as an instrument (or more smaller instruments if you want to
have separate kicks, toms, etc.)
I have done that just once but I would not like to do it again. I had
to guess a lot and since there were different velocity steps per drum
or cymbal I finally had to set a rather wide "merging" value in the EXS
to smoothen sudden loudness jumps - that reduces clarity of course.
Next time I would ask a person with more knowledge...
Anyway, if you like working with samples and EXS you might wait for
"Keymap":
http://www.redmatica.com/Site/Pages/KM.php
I am pretty sure that this software will make the job much easier once
it is available.
___
Peter Ostry
2005-05-06 by Gramophone
>> > NN-XT
>> > Logic;
>> > preferably EXS24?
I would use chicken system¹s Translator to convert, fast and easy.
And if ever the file gives you problems, Garth (product support) will help
you in a flash.
Louis
