VSL for EXS
2005-05-10 by Scott Schram
Julie Larson wrote: > Yikes....it's true....I just read it in the manual. I was planning on > using nodes to enable me to run VSL. I figured that I could off load > the fat VSL tracks to the node. How are people doing this? Maybe I > shouldn't buy VSL for EXS....Can you run Kontact as a plug-in and node > enable that? I'd love some input..... We have VSL for EXS, and use it successfully with several tracks (nothing frozen) on a dual 2.0 G5 with 4 GB of ram. It requires using virtual memory because the total size of the samples is much larger than the RAM. It's possible that OS 10.4 Tiger will help, there are overall improvements for the users of G4s, and even greater improvements for G5 users. I'm referring to the improvements to the concurrency of the kernel of the operating system as detailed in the review below. However, the limitation is probably having enough RAM to hold the short beginnings of the samples, and enough disk speed to load up the rest of them on demand. This might be beyond what the current crop of laptops can do without a lot of freezing. Laptop drives and firewire drives are not nearly as fast as the G5's SATA drives (and I think the current ones shipping are even faster than mine.) We use two drives in the G5, one for system, Logic and sounds, the other for vocals. Vocals just aren't very demanding, but I don't want it to glitch if we've got a good take. An interesting experiment would be a Firewire 800 external drive for vocals, and split the sounds between two SATA drives. There is an awful lot of seeking and reading when getting those samples. Here's a *very* technical and lengthy review of what's under the hood of Tiger: http://arstechnica.com/reviews/os/macosx-10.4.ars I use a G4 1.33 powerbook, and we initially tried using Logic on it. My hat is off to you who are doing that, it's like building a ship in a bottle. Maybe we'll see G5 Powerbooks this year! Scott http://schram.net
