exs24 not finding audio files
2005-09-20 by jazzdoctor73
Hi there. I'm running logic 6.3.1 on os9.2 and I have a problem with exs24 where with
certain sampler instruments the exs cant find the corresponding audio files, even
though all the files it needs are present in the exsamples folder on my powerbook
int.hd.
Does anyone know how to direct the exs to look for these files?Have tried everything i
can think of.
Thanks
Dan G.
Re: [EXS] exs24 not finding audio files
2005-09-20 by Garth Hjelte
>where with
>files, even
>powerbook
>int.hd.
>everything i
>can think of.
If the EXS loads an .exs file, and the paths are incorrect (meaning there
is no file with that name in the path that the .exs file stipulates), the
EXS will starting looking through whole drives to find the file.
You can generally tell the EXS where to look under Options - it will look
in either Local Volumes or External Volumes. I believe (not sure) that the
EXS will look through the whole drive of the incorrect path (if the drive
exists) regardless of what the options say.
So if the EXS does not find your sample, it may be because your Options are
set correctly to fine the file. Or it could be that the file name really
doesn't exist; for example, if the .exs file needs to find "brass 1.aif"
and the file is called "brass1.aif" it's going to miss it. It's got to be
exact, case insensitive.
Hope that helps!
Garth Hjelte
Sampler User
Hi, i sorted problem out by running project manager and scanning folders where the
samples were located. I then used the find unresolved file paths function to find the
samples and repair the faulty paths. I now have every sample working again.
2005-09-21 by Colin Shapiro
>folders where the
That's the way....
If you have very large libraries like Vienna Symphonic, you should
look at EXSmanager. It does the re-linking about 100 times faster
than Project Manager (not kidding).
Here: http://www.redmatica.com/Site/Pages/EM.php
Great product....
Regards - Colin
