I finally had a chance to try it, and on 6.4.1 (OS9) the command is cntl
plus "*". Also, finding out what it was called helped me to find it in
the key commands window.
Thanks for everyone's help!
Lenny
amgshaffer wrote:
>Lenny Stearns wrote:
>>Anyway, I was auditioning some piano samples in the EXS and started playing
>>something interesting (or so I thought), and I remembered hearing about a
>>command in Logic to capture the last x amount of MIDI events played. I looked through the online help, but didn't find it. Needless to say, I lost what I had been playing.
>>Could someone tell me what that command is, or even what it is called? I'm
>>using Logic Pro 6.4.1 on OS9.
>Hello Lenny:
>You are looking for "capture last take". In OS9, I believe it is the
>following two keys pressed at the same time: "control" and "*". That
>should do it. If not try: "apple" and "*" (this is the Logic 7.1
>version of capture last take).
>I use this all the time...I almost never record midi (or audio
>instruments) anymore...I just loop Logic and play. When I play
>something I like I simply capture last take. It's a great tool.
>Best of luck,
>Dave
>________________________________________________________________________
>EXS Users Group - new web forums! http://logic-users.org/forums/EXS
>- To UNSUBSCRIBE: email exs-users-unsubscribe@yahoogroups.com
>- Search the entire archive: http://logic-users.org/forums/EXS/search
>Yahoo! Groups Links
Lenny Stearns lens@...
Alexandria, Virginia
