Am 16.10.2006 um 02:20 schrieb Peter Ostry:
> There is a misunderstanding. Colin means the plugin "BPM Counter" but
> Ingo asked about Options>>Tempo>>Tempo Interpreter.
Still a useful advice. I wasn't aware of the BPM counter.
> Ingo, if you want to tap you may want to try MidiClock which is
> freeware:
> http://www.grantedsw.com
> It builds a kind of buffer beteen you and Logic because it measures
> your taps and sends a MIDI clock out which you can use to synchronize
> Logic.
Thanks for the pointer, I just tried MidiClock. No more sync errors
in Logic, but unfortunately it doesn't do what I need: I want to tap,
say, four times and have the sequencer start with the fifth tap. Thus
the sequencer and my tapping are immediately in sync. Logic's tempo
interpreter does this (if it would work properly).
This is probably what MidiClock's "count in" is supposed to do, but I
can't get it to work. The internal metronome of MidiClock starts
clicking with the first tap and continues clicking after the fourth,
and also changes tempo when I change the rate of my tapping. But
that's all, Logic doesn't start and no MIDI clock messages appear at
the MIDI output (it does both when Midi Clock's "count in" is off).
Also MidiClock cannot be stopped anymore, I have to quit it.
Seems like a bug to me. I'll contact the makers of MidiClock.
Ingo
