Re: [exs] Really good orchestral for EXS 24 and EXS velocity switching...
2001-08-25 by Kaveh Cohen
George, with version 4.7 or above of LAP and EXS24, when importing Akai samples, make sure the "merge" function is enabled at the bottom of the Akai convert window when converting Akai volumes. This will then prompt EXS to merge different velocity levels of the same patch which are separate presets into one velocity switching preset. This function was not present in EXS prior to version 4.7 of Logic. Janne, as far as orchestral samples go, there are no native libraries. The ones that convert the best are the Advanced Orchestra and the Miroslav Vitous. The Kirk Hunter Virtuoso Strings are by far the weakest of the lot, so I would recommend to stay away from them and invest your money in a realistic library like those mentioned above. Another thing to consider is the Roland Orchestral Family. EXS does not format convert Roland, however using Bitheadz' Osmosis, which supports Roland deemphasis, you can convert Roland patches to Samplecell, which can then be converted by EXS. I have the Roland Orchestral Family converted in this manner into EXS, and am very pleased. KC
> on 8/24/01 11:22 AM, Janne Anderson at janderson@... wrote: > > > Dear list, > > > > Are there any really good complete orchestral packages for the EXS 24? > > Meaning native, actually programmed for the EXS 24? > > None that I know of -- but I'm new to the EXS24 fold. I find the Advanced > Orchestra library to be quite excellent and it imported in just fine. > > Having said that, this library DOES have some shortfalls in it's preset > programming. For example, there are no velocity switched presets, switching > between loud and soft samples... Although there are both as separate > presets. I have found it very easy to combine them within the ESX24 by > simply copy-pasting from one to the other, then setting a velocity switch > point in the Zone window. > > George > > > To unsubscribe from this group, send an email to: > exs-users-unsubscribe@egroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
