EXS instruments scanning SOLUTION
2002-01-25 by renger
Hi, I got a solution for the scanning problem! I indexed my harddrive with Sherlock and now the scanning time is reduced from 8 minutes to 20 seconds! Renger
2002-01-25 by kurtgoebel@aol.com
Can you be a little more descriptive of how you index a drive in sherlock? Thanks << From: renger <renger@...> Subject: EXS instruments scanning SOLUTION Hi, I got a solution for the scanning problem! I indexed my harddrive with Sherlock and now the scanning time is reduced from 8 minutes to 20 seconds! >>
2002-01-25 by HELP@MusicBootCamp.com
Doesn't indexing itself take a long, long time? I disabled the feature because the time just irritates me. I also add items to my HD all the time and would have to index it often. -Jer
> From: kurtgoebel@... > Reply-To: exs-users@yahoogroups.com > Date: Fri, 25 Jan 2002 10:47:44 EST > To: exs-users@yahoogroups.com > Subject: [exs] Re: EXS instruments scanning SOLUTION > > Can you be a little more descriptive of how you index a drive in sherlock? > Thanks > > << From: renger <renger@...> > > Subject: EXS instruments scanning SOLUTION > > > Hi, > > > I got a solution for the scanning problem! > > I indexed my harddrive with Sherlock and now the scanning time is reduced > > from 8 minutes to 20 seconds! >> > > > To unsubscribe from this group, send an email to: > exs-users-unsubscribe@egroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
2002-01-26 by Colin Shapiro
>Can you be a little more descriptive of how you index a drive in sherlock? I don't think anyone answered this yet. Open Sherlock 2 Go to <File> menu and choose <Index Volumes...> Select the volume you wish to index. For multiple selection, use <shift> click. If you have never indexed, select <create index> or <update index> if you have. Boil the kettle, make tea, watch TV and have a rest......it'll take some time! Or, as someone already suggested, use the schedule feature for while you're asleep. Regards - Colin
2002-01-27 by Vinco
I know it's a bit offtopic but what's the point of indexing drives with sherlock ? I never used it before and I don't know the purpose of it ! Thanks Vincent Le dimanche 27 janvier 2002, à 08:52 AM, Colin Shapiro a écrit :
>> Can you be a little more descriptive of how you index a drive in >> sherlock? > > I don't think anyone answered this yet. > Open Sherlock 2 > Go to <File> menu and choose <Index Volumes...> > Select the volume you wish to index. For multiple selection, use > <shift> click. > > If you have never indexed, select <create index> or <update index> if > you have. > > Boil the kettle, make tea, watch TV and have a rest......it'll take > some time! > Or, as someone already suggested, use the schedule feature for while > you're asleep. > > Regards - Colin > > > To unsubscribe from this group, send an email to: > exs-users-unsubscribe@egroups.com > > > > Your use of Yahoo! Groups is subject to > http://docs.yahoo.com/info/terms/ > > >
2002-01-27 by HELP@MusicBootCamp.com
It's used to search text within documents. Let's say you've lost a file, but you know it's somewhere in your drive. You just don't know where or what it is called. Once indexed, you can find that file based on it's contents. That's why it takes so long to index... there's a whole lot of data in there. Apparently, judging from the other posts, it also helps the finder keep very specific track of where everything sits. That would explain why the EXS24 search is sped up so dramatically. Still, a surprising perk none the less. -Jer
> From: Vinco <vinco@...> > Reply-To: exs-users@yahoogroups.com > Date: Sun, 27 Jan 2002 11:23:04 +0900 > To: exs-users@yahoogroups.com > Cc: Vinco <vinco@...> > Subject: [exs] about indexing > > I know it's a bit offtopic but what's the point of indexing drives with > sherlock ? > I never used it before and I don't know the purpose of it ! > > Thanks > Vincent > > > Le dimanche 27 janvier 2002, à 08:52 AM, Colin Shapiro a écrit : > >>> Can you be a little more descriptive of how you index a drive in >>> sherlock? >> >> I don't think anyone answered this yet. >> Open Sherlock 2 >> Go to <File> menu and choose <Index Volumes...> >> Select the volume you wish to index. For multiple selection, use >> <shift> click. >> >> If you have never indexed, select <create index> or <update index> if >> you have. >> >> Boil the kettle, make tea, watch TV and have a rest......it'll take >> some time! >> Or, as someone already suggested, use the schedule feature for while >> you're asleep. >> >> Regards - Colin >> >> >> To unsubscribe from this group, send an email to: >> exs-users-unsubscribe@egroups.com >> >> >> >> Your use of Yahoo! Groups is subject to >> http://docs.yahoo.com/info/terms/ >> >> >> > > > > To unsubscribe from this group, send an email to: > exs-users-unsubscribe@egroups.com > > > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/ > > >
