RE: [exs] RE: Translator question
2002-03-25 by fernstudio@telus.net
Hi, Bernard wrote, > Is it just me ? But when I convert a Roland patch to the EXS24 format with > and without the deemphasis and even though I see "de-emphasizing sample" > on the progress window, every time both .wav files sound exactly the same. > I don't trust my ears enough, so I used Wavelab to compare the original > sample and the de-emphasized sample and there is not a single bit of > difference between the 2 files. A pure placebo effect ! Well, there are quite a few options for the Roland Emphasis curves. I don't recall what the default settings are but there are a few options. You can have the authentic Roland curve, darker, lighter, standard (Translator's original curve for Roland coversion), special and custom. It can also be enabled or disabled as well. Is it possible that perhaps it is disabled but a message is displayed where it normally applies the de-emphasis? I tried it out when I first got Translator and it worked fine for me. I didn't compare it to a S-760 (as I don't own one anymore) but there *was* a difference. I'll have to remember to try it out again tonight when I have some time. Interesting that you're trying to make a wave here when you are the developer for Translator's main competition. I'm sure Garth could be here and other places trying to point out things that he may have found in your product but I don't see him doing that. Hm-m-m-m Fernstudio ================================================================= Internet service provided by telus.net http://www.telus.net/
