Re: Garritan EXP
2003-02-14 by Mike Auty
Hi Ned / Julie, In addition to the keyswitching patches, it is not too difficult to get the EXP patches working too. I thought this had been discussed here before, but I could be mistaken. Anyhow, here's the lowdown: EXS doesn't seem to import the velocity ranges for each layer correctly. So just pop into the editor and assign each layer a velocity range (ie; 1-32, 33-64, etc.) Then in the routing matrix, assign sample select to control 1 source instead of velocity. You might want to bypass the usual 'vibrato' assigned to the modwheel, but i'll leave that up to you... :) By now, using the mod wheel should switch between sample layers; you just need to apply some crossfading to smooth the transitions... Now if only the legato patches would work somehow.... -mike On Friday, February 14, 2003, at 12:38 AM, exs-users@yahoogroups.com wrote:
> No, I only use the simple patches in GOS. AFAIK, all the GIGA formating > does not work in EXS (except the Keyswitching). I'm hoping that Gary G > will > do an EXS version of the library (I'll write him today to see if > there's > any chance in the near future. Don't hesitate to write me to see what > he > answered). In the meantime, the sounds are great enough for me to get > a lot > of work done! > > :-) > > Julie Larson wrote: >> Hey Ned...while you're there....are the EXP patches, from your >> Garritan >> String Library, functional in the EXS.
