EXS24: Won't recognise Akai CD!
2003-02-15 by Paul Zimmer
I'm trying to convert an Akai CD that contains both audiofiles and Akai
Programs/Samplefiles, but EXS24 doesn't seem to recognise it.  Initially, my
Mac just spat the CD back out, but I've managed to get it to swallow it by
launching Toast first.
I've had no problems converting other CDs (which contained no CD audio
tracks), so I'm assuming that it's the mix of audio tracks and data that is
confusing it?
Any help is appreciated!
Paul Zimmer
(ZAP! - Zimmer Audio Production)
www.zimmeraudio.com
Re: [exs] EXS24: Won't recognise Akai CD!
2003-02-15 by Rubber Chicken Software Co.
At 05:37 PM 2/15/2003 +0000, you wrote:
>Hi,
>confusing it?
Download the Apple 1.3.5 CD/DVD Driver, you can get it at
www.chickensys.com/translator/download - put it in your extensions folder,
disable the newer one and enable 1.3.5. Restart. Your EXS probably will see
it then.
The problem (although yours seems different) is that the newer versions of
the Apple driver do not report the disk areas other than the Audio one once
the Audio area is reported. This affects all Mac programs that attempt to
read any Audio/proprietary Mixed-Mode CD, as it's an Apple problem in the OS.
This answers the other chaps' direct question as well.
Garth Hjelte
Sampler User
RE: [exs] EXS24: Won't recognise Akai CD!
2003-02-16 by Paul Zimmer
Hi Garth,
Thanks for the advice - I will give that a try.
Paul Zimmer
www.zimmeraudio.com
> From: Rubber Chicken Software Co. [mailto:support@...]
> Sent: Saturday, February 15, 2003 9:51 PM
> To: exs-users@yahoogroups.com
> Subject: Re: [exs] EXS24: Won't recognise Akai CD!
> >Hi,
> Initially, my
> swallow it by
> data that is
> >confusing it?
> extensions folder,
> probably will see
> it then.
> versions of
> Audio one once
> problem in the OS.
> Garth Hjelte
> Sampler User
Multiprocessor Support
2003-02-16 by Jer Olsen
In OS9, which environment audio objects are loaded onto the other processor?
I'm fairly certain the live inputs are one thing. Are there any other
objects? -Jer
Re: [exs] Multiprocessor Support (another question)
Another question, is there any way to utilize the live input tracks for more
typical tasks so in order to take some load off the CPU driving all the
plugins? -Jer
> objects? -Jer
2003-02-16 by Eli Krantzberg
> plugins?
If you have a multi I/O audio interface, try physically plugging some of the outs to the ins. That way in Logic you can assign the output of a bus to an output that corresponds with a live input set to receive from the physical inputs reciving those outs. That way you can assign a heavy reveerb plugin for example to the live inoput. And "send" to the above mentioned bus in order to utilize it.
For example:
Bus 1 is set to output 7-8
patch outputs 7-8 to inputs 7-8
set up a live input with ins 7-8 assigned to it
put a reverb plugin on the live input object
now send to bus 1 from your audio tracks in order to utilize this reverb being used on the second processor.
> > objects? -Jer
The I/O plugin causes the track it is assigned to to use the second processor.
Eli Krantzberg
Nightshift Orchestra / Almat Productions
http://www.nightshiftorchestra.com
2003-02-17 by Jer Olsen
Not too bad an idea. Thanks. I've scrapped an old mix of mine (one that kept
clicking and crashing) and started over. I'm noticing that the distribution
of processing responsibilities seems to be better distributed on OS9 than I
thought. Maybe the track plugins are on one and the bus plugins are on
another? Hard to say by looking at the meters, but this mix is going much,
much better.
>> plugins?
> utilize it.
> For example:
