midi on/off triggers
2003-02-21 by Josh Ford
Does anyone know if and how I could set up a logic
environment so that my midi keyboard can trigger
samples on the EXS24II where one keypress will trigger
a sample to play until another key press stops it?
I basically want to set up a system where in a live
situation I can trigger loops to play continuously
without having to use masking tape to hold the keys
down.
Does that make sense or am I talking gibberish?
Many thanks
JF
Do You Yahoo!?
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
Re: [exs] midi on/off triggers
2003-02-22 by Hendrik Jan Veenstra
>down.
Doable, but somewhat tricky.  Pass the note-on and filter the
note-off, then remember which note is being played, and as soon as
the next note arrives, send a note-off for the currently playing
note, and pass the new note-on, filter the note-off, etc...  Some
time again I made something similar for someone.  I'll have a look
and see if I can dig it up...
Hendrik Jan Veenstra  <h@...>
Omega Art: http://www.omega-art.com
2003-02-22 by Bill Canty
> >down.
Hmmm, couldn't you just use TouchTracks for this?
2003-02-23 by mandcmiller <mandcmiller@earthlink.net>
> > >down.
Set up a monophonic group for each loop and assign a dummy zone (with no
sample) to the same group to be use as the loop's mute key. So each group
would have a loop and an associated dummy key for muting. If you want one
loop to cancel out another, simply assign multiple loops to a monophonic
group.
-Matt
Re: [exs] midi on/off triggers (addendum)
--- In exs-users@yahoogroups.com, "mandcmiller <mandcmiller@e...>" <
> > > >down.
BTW - To allow the loops to uh.... loop, you can apply Hold as a destination in
the mod matrix with Key as the source. This will allow the loops to "Latch" or
continue indefinitely. It seems that you do have to assign a sample to the
dummy zone so, I would suggest a HH or something similar and just attenuate
the volume so it is not heard.
